ksrokiller
- Nov 17, 2007
thx. that's pretty std. a good deal.
Np, wanted get sys 3 but 1 room dont really use aircon so get 2 instead.
To qrsy2k,
For 4 room flat, 18k btu is good enough.
5 room flat to use 24k btu.
38k btu compressor is an overkill unless you on all 4 units at the same time often.
Can I just ask if this Gain City $99 for 5 years warranty is a good, legit idea? Heard it's still chargeable despite the "warranty".
Not to mention GC will jack you on the pipe from 22 to 23 gauge when installing; or was it the other way round. Happened to my friend.
Just bought mits heavy industry
Sys 3. Room is 9k btu. Living room is 12k btu.
Total 3100
looking for Mitsubishi starmex sys 2 , but I'm confused why the old 4 ticks now all 2 ticks nia ?
what models are the new 5 ticks ?
is there any panasonic models with 4 or 5 ticks ?
also i see installation done with quality materials, which shops will do installation with the good material?
also 20000 btu cu is enough for 2 9000 btu room units ? if so y some units sold with 28000 btu ?
Regards
