Fury price drop imminent
royfrosty
$809 good pricing leh. If i choose to go oil cooling rig, i might go fury Nano or go for any other air cooling gpus in future.
shadow84
In any case, its just a bloody name... What matters is the price and performance.. lol.
royfrosty
It is still a FULL Fiji cores that is found in Fury X hor. Just cut down of power till 175w. And priced at 799 is just way too good. Its even cheaper than some gtx980. Yet performs better than the 980 with less power.
Slap in a good cooling solution it can work even better under water.
robolee
dun have the talent to custom cool nano :(
helios467
Is the nano now worth to get, for 1440p setup?
I'm using the qnix 27 inch monitor, and still using my gtx670 (which has served me damn well) for only medium settings for BF4.
Or wait for the new tech thats coming out this year?
royfrosty
Single card yes. It is found to be the same performance of a Fury. A single card 1440p is more than enough.
BUT since you are using qnix, you have no connections to use any of the fury series. And adapters wont work.
