Good Dual Sim Phone
SExiao
As above, other than the LG G4.... or should wait a bit longer for upcoming ones, if there is one?? :s11::s22:
Norman Chan
Try Oppo R7S , has used it during HK and Thailand trip so far so good. SIM1 will drop to 2G (Singapore Line) but still can receive normal SMS and make call and SIM2 local card can connect to 4G and Data plan,to use with all SIM1 data Apps applications like WhatApps , LINE and Goggle Map etc.
Intrinion
Senior Moderator
Senior Moderator
I believe the new Samsung A series (2016) does have lte dual Sim capabilities too. :) Do check them out.
The A3 /A5 would be the one I would suggest you take a look at!
Cheers
cwchee
Can share your experiences with One Plus 2 when using in overseas ? How the SIM1 and SIM2 perform ?
It works like how all current dual sim does.
One sim card will be able to connect to 4G or 3G depending on the sim card and network.
The other one will be on 2G for calls and sms only.
I normally fly to places like china, Myanmar, philippines and Indonesia.
All working well due to the fact that OP2 supports alot of network bands.
Hope this helps
Ibodnano
Why no one suggest Lumia dual sim phones?
I am using Lumia 640 dual sim bought from Malaysia
amazingone
2nd Sim slot as mSD card slot, most of the new dual sim phone is having this.
Nope, for the A5 (2016) and also the A7 (2016), it features two SIM slots and a standalone micro SD slot.
http://forums.hardwarezone.com.sg/samsung-user-group-136/samsung-galaxy-a3-5-7-2016-a-5231749.html
Sent from using GAGT
Jurchen King
ZTE Axon :). Flagship specs and all the bells & whistles at budget re-contract price. Camera is best feature.
You can thank me later.
