which AT transmission ?
human1969
Hi,
Have been driving Manual for all my previous cars.
Thinking to consider AT for my next car.
Understand there are several variant for AT transmission. (regular, DCT, CVT etc)
While not a racing guy, i'm rather heavy footed driver (cos driving small car),
Hope to look for an AT transmission that can last 10yrs :D
Any bros can advise which is the more reliable or proven type ?
Or any brand\type must avoid ?
early stage consideration is:
- Swift / Sport
- Veloster
- Toyota 86
Appreciate your kind advice...Tks
yanbros
For small cars, do keep away from vw under 2 litres. Their dsg gearbox is well known to be faulty. Other than that, to keep a gearbox in good running condition, change the gearbox oil regularly. Even if the owners manual states 20k or lifetime no need to change, be a little bit more kiasu and change it maybe at 10 or 15k intervals. Especially if you are heavy footed.
Genesisz
I agree.
Avoid the VW 1.4l models which are equipped with the dsg 7 speed "dry" clutch gearboxes.
As between traditional AT and CVT gearboxes, I have better experiences with the CVT transmission.
human1969
Looks like the newer AT dont have much fans.
Trying hard to avoid conti, so VW is out.
Thanks for you the inputs !!
Keep them coming :D
ZhuTou!
Avoid 7dsg dry clutch can liao
The rest is ok but make sure to change the atf every 30k
HeadQuarters
CVT is not suitable for heavy-footed drivers...
U can floor the accelerator, but the car will not pick up much :s13:
CCCustom
- Swift / Sport
- Veloster
- Toyota 86
I find it unusal that a shortlist will have 3 different class cars at 3 different price points. It's like someone saying, should I buy a Kia, a Honda or a Mercedes ;)
Dragon
Administrator
Hi,
- Swift / Sport
- Veloster
- Toyota 86
Between the 3 choices, the Toyota 86 gets my vote. :)
human1969
Ya, my thinking more towards small is beautiful.
All my previous ride are below 4m length.
Sedan is definitely out, cos dun like big/long car.
So 2+2 seems to be the sweet spot for me.
Think 4.2m is the max length i will consider.
Actually not much choice i have.
Was interested in RCZ, but out of productn liao.
All the feedback i gather on Peg also not very encouraging.
Not really a car aficionado,
my consideration base more on look & reliability.
If it have the look (RCZ), then i dont mind increase my budget,
if its just B&B car (swift), then will trim my budget down.
OysterJianHao
swift sport is the ideal small compact powerful car, if u frequently going up north holiday is good enough especially conquering the genting route...
