IOS/ Android Summoners War: Sky Arena - Part 2
Jarlaxle
Velajuel and chasun combo ***** pain in the ass in arena. Long battles cannot outdone them. Dulan tmd.
dun hv a good answer for u.
im not sure what was the 3rd mon that he has.
i like to use kahli against such teams as long as there are no water dps.
the good thing about such team is that theres usually no dps.
dont hesitate to bring 2 dps!
yang_nastyman
decided to try db8 for fun, turns out i can clear it without a healer by using cadiz instead o.o
should i continue with gb10 or go db8 then??
WhyNPNT
got dps and reviver. theomars + briand + chasun + velajuel. and also met another vanessa (lead)+ theomars + chasun + velajuel. super pissed off.
Destroy Runes still subpar imo.
if your AD can make drag long battles, destroy runes actually super good.
play the way you like la. that time i whack db6 everyday even though the drop sucks. then slowly i got better violent runes and upgrade slowly up to db8 then now db10 le.
Jarlaxle
dun waste time n energy to farm 3* n 4* runes from db8.
continue with g10 until u can do d10
H1s0ka
Is fire monkey king n fire desert queen any good? What rune for them? New player here.
yang_nastyman
Lock them first, then put them as your arena defense to show off.
they're salt generators
now i feel like buying the legendary pack to summon, but ill probably get magic knight
tckrto
U new player? Then whatever atk rune. End game will still be a long way.
I build mei hou Wang violent revenge. Atk, CD, HP put as AD during rush hour.
tckrto
Told u guys just summon for fodders. I just got Verad, baretta, fire horus from 12ms
Well not much use since got Poseidon.
