Head/earphones Recommendations Thread
zephyr
- Your rig: samsung phone
- What type of usage: music
- File format used in your source: mostly mp3
- Genre of music you listen to: all kinds tbh
- Headphone / earphone type: in ear
- Other requirements: no vol control, preferably pink
- Budget: $400
Thanks
LouisLoh
With that budget I'd recommend a low-end CIEM. I'm a bit out of touch in that area, but examples would be JH5 and AAW CIEMs, and a google search should bring up similarly priced models from other manufacturers.
When you go customs, you'd be able to personalise the appearance to your delight.
afishpie
deciding between the jh13 and fitear 335s for my ciems, both are really amazing to me but the fitears just sounded a lil better. Not quite sure if the huge price difference is worth it. any pros can advise?
thanks!
XcoldstarX
thanks!
Hi, what brands of CIEMs have you tried?
Boner
Hi,
is U JAYS headphone available in Singapore? there is a lack of review online about this product.
obichacha
thanks!
Might to share where did u try thems out?
KlavierX
Would you guys recommend a Marshall Major II ?
if you got bigger head maybe not, go for comfort and if you have more budget can go for the marshall monitor. the marshall major still sounds good though but comfort wise it gets to me
SKinny86
You will be surprised what the RHA T20 can pump out.
One of my favourite IEMs now. :D
Being dynamic drivers, it gets better with burn-in.
:s12:
My friend has the T20 and i'm using umpro 30. We compared side by side and find that the Westone has definitely better sound stage.
Mids and highs are clear and well separated compared to T20.
I agree that dynamic drivers have good bass depth, but the triple armature drivers also gave solid punch in bass, which felt something like a bass drum.
KlavierX
Hi anyone know if ATH-WS550IS is good for casual gaming, and movies/music?
Can check if soundwaves still have the Audio technica gaming headphones those are good, but casual for comfort if you don't wear long hours not so bad
obichacha
I had another good thing to recommended you guys here, please try with REMAX RM-610D, price from $20-25 only.
I guess you same as me can't expected the high performance IEM and selling cheaper only.
obichacha
Should try with T200 comply
