Xiaomi Mi Note
poppychua
Hi i using mi note pro on china rom... My whatsapp keep hang... I need to open the app than all my msg com in... Anyone having this issue too.... Tks....
Computeron
IS HANG OR LAG?
miui has this problem of lag msg coming in.
some1outthere
MIUI has native support for wireless display. Can stream the entire phone display to chromecast.. sweet..
nagase_4
Hi, I'm currently holding on to a China set redmi note 4G (dual sim version, I think). I don't think it's a local set but how do I confirm? The white sticker with the Barcode on the phone box, the text are all in chinese.
May I ask where can I download a global rom for my phone or which version should I download?
Thanks in advance!
Audiology93
Check if your box have the IDA sticker. If have then means local set.
Thanks in advance!
iewislove
hey guys im actually looking at getting a Xiaomi note 64gb brand new at $355 or getting a Samsung note 4 pre-owned at $400 no more warranty . Which one you guys will prefer to get if u were me? i cant decide on this 2 and i also looking around for Xiaomi note pro but doesnt seems to find a reliable store in sg to get 1 at a decent price.
My budget is less then $450 tho , not sure which 1 to get.. any recommendation ? isit still worth to get Mi note ?
JuXn5566
Note4 is better than Mi Note in couple of ways but Mi Note is still good device for most people. The glass/metal build, light weight,hifi and dual-sim function is something you can't get on Note4. It's up to you to decide if you want to purchase a higher priced but better overall device with no warranty or pay less for a good phone with warranty. Don't get Mi Note Pro, the batt life is bad and there's no global rom support.
