HDMI adapter heating up issue
VacheronLim
Needing some advice here, I got a monitor with only VGA port, and a CPU with DVI (24 + 1 pin) & HDMI port
am currently using a HDMI to VGA converter adapter (bought from http://list.qoo10.sg/item/HDMI-TO-VGA-AUDIO-ADAPTER-OPTION/415173938?selectedOptions=), but after using a while when the adapter becomes hot, the screen keeps turning black for a split second (and repeats)...no gaming usage, only basic web surfing
Had use this same monitor on another CPU (VGA to VGA connection), totally no problems after prolong usage so likely the adapter that is the root cause...
Is this a case of faulty adapter? how should i troubleshoot this? the dvi to vga converter i found are all 24 + 5 pins (which won't fit into the 24 + 1 that I have)...
yusoffb01
24+1 means digital only cannot convert to vga
24+5 has both digital and analog signals so it can convert to vga
Either buy another converter
Another monitor
Another graphics card
VacheronLim
where should i look at to get a reliable converter? don't want to end up with the same problem with a better converter ><
can i say that with higher usage (e.g gaming) the converter will turn hot faster?
Should use dvi-vga adapter.
:D
TS should go try this.
jedi5diah
gd thing the trend now is DP n HDMI
try another one, you might just got a faulty one.
jedi5diah
Will dp n hdmi ever fusion?
from my limited knowledge DP is PC tech moving forward and HDMI is AV standard which is common on almost all consumer electronics so they will still support for pc parts for reaching the masses. also because hdmi got 1.4a (2. also out for 4k 60mhz support i think) can cont. to upgrade in future...
VacheronLim
yes indeed the standard dvi (24 + 5 pins) won't work for my situation as the dvi on cpu 9s 24 + 1 pins
will get a replacement and see if the problem still persists :D
i suppose a fully functional adapter shouldn't be too hot (on normal usage - web surfing only)?
Nakedtoes
Have u solve the problem? Dun get cheap adapter from China
VacheronLim
waiting for a replacement adapter to test if the same problem occur, any recommendations of which brand to go for such adapter (in case the replacement resulted in the same problem)?
jedi5diah
like belkin and lagi best if got usb powered ones...but cost around 60-100++
t258jgn
Astone HDMI v1.4b to VGA + SPDIF & 3.5mm Converter @ $40
