chomechome
- Jan 17, 2002
For those who shipped xiaomi from taobao do you need to declare anything? Since there's a lithium battery and batter is not allowed to ship via airline
just go by sea, and you do not need to declare anything.
I think there's no way you can ship by air for phones and tablets.
i read about the note 3 on how to do a reset and install the google play yourself. is that the same for redmi 3?
Installing google playstore is a piece of cake. Tons of google playstore apk file out there. Don't need any tech knowledge at all. However, would recommend you go miui forums to get the apk for installation as those there are safer compared to whatever you got via google.
anyone know where to get TG for this phone?
tempered glass if im not wrong, taobao or aliexpress may have, xiaosen may want to check it out.What is TG?
i bought my gold redmi 3 with the tempred glass and back case from qoo10 for $180...
Now i see 198 sgd for phone alone. Like the big batt though. Very tempt to buy.
Sent from my Rice phone using GAGT
RMN3 is more advanced than RM3 in terms of specs(eg. SD650 vs SD616, 16MP vs 13MP, 5.5" FHD vs 5.0" HD, fingerprint reader on RMN3 etc.).RM3 and RMN3 difference $20+ odd on Lazada... Hard to make a choice lei.. I am already on IP6s+ as my main line and using RM2 as a 2nd line and looking to replace the RM2... Which will u choose?
Since you're already using RM2 now then RM3 should be similar. The RMN3 has the same screen size and resolution as your 6s Plus, but battery wise RM3 may be better due to them both having 4000mAh battery but RM3 only has a HD screen thus might be less taxing on the battery.
edit: Here's a battery test on RM3 by GSMArena~
