HWZ Forums
Login Register FAQ Mark Forums Read
[Help] Connecting 4 ARGB fans
Reply
LinkBack Thread Tools
Old 12-09-2019, 03:57 PM   #1
dennis7w7's Avatar
Hi all. I just bought the Cooler Master ARGB 3 fan pack for my rig. As there is already an existing ARGB fan in my current rig, any idea how to connect 4 together? As they only provide a 1-to-3 ARGB splitter and my mobo has only 1 ARGB head.
Recommend any setup needed. Thanks!
Processor
AMD RYZEN 5 2600 3.4Ghz
Mainboard
ASRock B450M Pro 4
Graphics Card
ZOTAC GTX 1070 8GB Mini
Memory
Klevv 2666Mhz 16GB
Display
Dell SE2417HG
Storage
Lexar 240GB M.2 SSD + Seagate 2.5" 1TB HDD
Casing
NZXT H500 Black
PSU
FSP Hyper K 600W
Audio
Logitech Z523 2.1 Speakers
OS
Windows 10 Home 64 bit
dennis7w7 is offline   Reply With Quote
Old 12-09-2019, 04:18 PM   #2
https://www.coolermaster.com/catalog...ll-controller/
https://www.coolermaster.com/catalog...20r-argb-3in1/
shadey is offline   Reply With Quote
Old 12-09-2019, 04:39 PM   #3
dennis7w7's Avatar
The website doesnít says anything about connecting more than 3 ARGB fans.
Processor
Mainboard
ASRock B450M Pro 4
Graphics Card
Memory
Klevv 2666Mhz 16GB
Display
Dell SE2417HG
Storage
Casing
NZXT H500 Black
PSU
FSP Hyper K 600W
Audio
OS
Old 12-09-2019, 04:49 PM   #4
Buy another 1-3 splitter or connect fans to the controller and then use a splitter to connect ur argb fan and controller to your mobo.
If not, this is the limitation of Cooler Master products, just have to accept it.
__________________
Life is short, live to the fullest.
Processor
Ryzen 5 2600 w/ EK Supremacy EVO Nickel Plexi CPU Block
Mainboard
MSI X370 Gaming Pro Carbon
Graphics Card
Palit GTX 1080Ti FE w/ AQC Kyrographics Nickel Plated water block w/ Acrylic Glass
Memory
G.Skill SniperX 2x 8GB 3200Mhz CL16
Display
Samsung C32HG70 32" 1440p 144Hz HDR
Storage
Samsung 960 Pro 512GB (OS) / Toshiba 5TB HDD
Optical Storage
这能不能吃的啊?
Casing
Lian Li PC-O11 Dynamic / 6x Gentle Typhoons AP-15 / 2x Bitspower Leviathan Slim 360mm Radiators
PSU
Seasonic X-850W 80+ Gold with White Sleeved Cables + Cable Combs
Audio
Topping DX7 DAC / JBL LSR305 Speakers / JBL LSR310s Subwoofer
OS
Windows 10 Pro 64-Bit
shadow84 is offline   Reply With Quote
Old 12-09-2019, 07:17 PM   #5
meandyou's Avatar
If there is only 1 argb header on ur mobo, You need to get another argb Splitter and daisy chain it.
meandyou is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
