HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree58Likes
Reply
LinkBack Thread Tools
Old 17-07-2016, 08:32 AM   #151
ZrE0_Cha0s's Avatar
Need to upgrade my bro's com.
His main usage: Photoshop, Illustrator and light gaming.
Budget: $600 without monitor, kb and mouse.
bro, maybe u can list the parts he has so we can see which parts to upgrade.
ZrE0_Cha0s is offline   Reply With Quote
Old 17-07-2016, 10:01 AM   #152
ZrE0_Cha0s's Avatar
Hi, Need recommendations for a setup. Budget 600. Budget excludes OS.
No need gfx card as i have a geforce 770 sitting at home. No need monitor kb mouse as well.
Will be using it for gaming (csgo) and watching videos
Asrock H81M -HDS + i5 4590 @358
Kingston DDR3 8Gb @48
Zotac 240GB@99
Total: 505
well im not sure if its a totally new build or upgrade.
but i did reco u just upgrade.
therefore i did reco u to reuse ur case and hdd as well.
edit: all price are quote from PCThemes.
Old 17-07-2016, 10:04 AM   #153
ZrE0_Cha0s's Avatar
Hi need recommendation for CPU/GPU for an upgrade from my current 4 yo laptop. Build for gaming
Currently can obtain following:
i7-6700k + gigabyte z170x gaming 3
Gskill Trident Z 3000 MHz C15 8x2
Crucial MX 200 250GB
Cryorig A80 AIO
Corsair RMx 850W PSU
NZXT H440
SUM ~ 1400 SGD
Currently have monitor keyboard mouse
Storage going to strip down an existing WD ultra portable drive
Have an available win 7 install that can upgrade to win 10 for free by Jul 29
Was wondering if I can save about 50 bucks going for i5-6600k instead? i7 worth the extra 50?
Considering an AMD RX-480 AIB when it comes out in maybe a week? Or spend cash on 1070?
budget: can spend another 400 bucks, but maybe can push to 600 if I eat cheap for the rest of the month
well if u are ok to spend a bit more just go for i7 for future titles. and i rather u just get a better GTX 1070 - 1440p but if u going for 4k gaming still better get GTx 1080.
Old 17-07-2016, 10:07 AM   #154
ZrE0_Cha0s's Avatar
Can get recommendation for New vr rig - but Budget conscious...
Eyeing at most gpu Nvidia 1070 and no need monitor & speakers. Feel free to pm me too!
how much budget u will spend? if u want GTX 1070 wont be too budget. and currently GTX 1070 have VR issues with certain brand VR, not sure if new driver can fix the issues or not. else u can consider getting rx 480
Old 17-07-2016, 11:22 AM   #155
Hi all, i would like to build a new system, my old PC died on me.
Would like to have a recommendation on what I need to get.
My primary usage is gaming (witcher 3, FO4, BF 1) Would like to play these on ultra high graphic setting. Secondary usage is editing like adobe illustrator.
Will not overclock, using single screen. Do not need a screen, speakers, keyboard or mouse.
My budget is $2500
Thank you!
Snapplekid50 is offline   Reply With Quote
Old 17-07-2016, 11:57 AM   #156
AaronZzZ's Avatar
Hi,
Needs total rehaul.
Current parts:
AMD X2 4600
MSI K9NGM3
2x512mb
HD2600 Pro 256mb
Processor
Intel i5 2400
Mainboard
Biostar TH67+
Graphics Card
MSI HD5850 TwinForz II 1GB
Memory
G.SKILL Ripjaws Series 8GB (2 x 4GB)
Display
Dell U2311H
Storage
Samsung F3 1TB, Western Digital Green 500GB
Optical Storage
Samsung 22x DVDRW
Casing
Cooler Master HAF 912 Advanced
PSU
Andyson F500M
OS
Windows 7 Ultimate 64bit
AaronZzZ is offline   Reply With Quote
Old 17-07-2016, 01:23 PM   #157
ZrE0_Cha0s's Avatar
Hi,
Needs total rehaul.
Current parts:
AMD X2 4600
MSI K9NGM3
2x512mb
HD2600 Pro 256mb
but to overhaul such usage with 600 is kinda tight though. u might end up using onboard gpu.
Old 17-07-2016, 02:13 PM   #158
ZrE0_Cha0s's Avatar
My budget is $2500
Thank you!
Gigabtyle GA-H170-D3H + i7 6700 @630
Palit GTX 1080 @999
SF Ledex 650W Gold @159
FD Define R5 @149
Samsing Evo 850 500GB @255
WD 2TB Black @182
total: 2374
All prices are quote from PCTheme.
Old 17-07-2016, 05:15 PM   #159
Within 2k if possible? And Just for CPU alone, no need other stuff like speakers, monitor, etc. will pair with oculus, not vive so not too concerned hehe. You have any idea when gtx 1060 may be available?
wlcling is offline   Reply With Quote
Old 17-07-2016, 05:46 PM   #160
Any gaming non-overclock motherboard to recommend? And gaming 2K monitor. Playing AAA games at highest settings across all genres.
Palaxius is offline   Reply With Quote
Old 17-07-2016, 08:22 PM   #161
Palit GTX 1080 @999
FD Define R5 @149
WD 2TB Black @182
total: 2374
Many thanks zreo
Could you recommend me the RAM (16vs32) and ODD as well?
Would'nt mind going a little above budget for it.
Lastly, possible to recommend a screen that would be good with the GTX 1080, budget $500?
Old 17-07-2016, 09:40 PM   #162
ZrE0_Cha0s's Avatar
Many thanks zreo
paiseh forget to add ram in
well im not sure how heavy u are using for photoshop, but 16GB is enough, if u willing to throwing more is up to u.
As for ODD, do u need a blueray type or dvdrw kind? blueray im not sure, but dvdrw u can get asus @25 same shop.
well as for ur usage, u can consider these 2:
Dell UltraSharp 24 InfinityEdge Monitor | U2417H
Dell UltraSharp 24 Monitor U2415
http://accessories.ap.dell.com/sna/s...asharp_monitor
Old 17-07-2016, 09:41 PM   #163
ZrE0_Cha0s's Avatar
sorry i dun get what u asking for a mobo when what u want seems like the gpu .
Old 17-07-2016, 09:42 PM   #164
ZrE0_Cha0s's Avatar
ya 2k should be more than enough for a VR build. and GTX 1060 will be available on the 19th July, which is 2 days later.
so if u want a build with GTX 1070 or GTX 1060?
Old 17-07-2016, 09:56 PM   #165
Go with 1070!
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
