HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree55Likes
Reply
LinkBack Thread Tools
Old 20-07-2016, 11:06 AM   #181
ZrE0_Cha0s's Avatar
saw on lazada that zotac 980ti 6gb amp is 599. i think is 100 cheaper than zotac 1070. i guess just basic features? cause i rarely game. can support up to 32 or 64gb is good enough. don't plan to SLI. need wireless support. Is there other features required ?
someone just pm me that he selling his Superflower leadtek 550watt 90+ silver rated psu for 95. is it a good buy? he just used it for 5 hours.
wow that seems like a good price to consider.
as for the psu ya its a good buy even with just 5 hours.
so maybe u can go with this build :
MSI H110i PRO + i7 6700 @538
Curical DDR4 16GB (2x8GB) @94
TT cover V21 @89 (cybermind)
Total: 721
All price are quote from Tradepac, otherwise stated.
i have not included those 2 (PSU and GPU).
ZrE0_Cha0s is offline   Reply With Quote
Old 20-07-2016, 11:47 AM   #182
Total: 721
I no need the rams since i already have them.
So i'm thinking of
superflower 550w @95
Zotac 980ti 6gb amp @599
Total is $1321
__________________
Overcome Fear...
GiLLiaN_Chung is offline   Reply With Quote
Old 20-07-2016, 11:53 AM   #183
ZrE0_Cha0s's Avatar
So i'm thinking of
Total is $1321
u mean u have DDR4 rams?
Old 20-07-2016, 11:58 AM   #184
I think is DDR3. is there alot of difference? cause i have 32gb ddr3
__________________
Overcome Fear...
Old 20-07-2016, 12:06 PM   #185
joshuaho's Avatar
Ddr4 and ddr3 Rams uses different slots, moreover motherboards usually either fit ddr3 or ddr4, not both
Processor
i7 7700k 5.1Ghz (LC & Delid)
Mainboard
Z270i ASUS PRO GAMING
Graphics Card
GTX 1080ti MSI Gaming X 11GB (LC)
Memory
32GB Corsair Vengence 3200Mhz (2x16GB)
Display
ASUS MX27AQ BenQ XL2420T
Storage
Samsung 500GB 960 PRO M.2
Optical Storage
Casing
FRACTAL DESIGN NANO S
PSU
COOLER MASTER V1000
OS
Windows 10 PRO
joshuaho is offline   Reply With Quote
Old 20-07-2016, 12:23 PM   #186
So if the motherboard supports ddr4, i cannot put in ddr3?
__________________
Overcome Fear...
Old 20-07-2016, 03:28 PM   #187
Hi guys,
i want to buy a new desktop for myself to play video games and watch movies.
Games i usually play are WOW, Overwatch, Starcraft, CSGO and usually new games on the market i probably will buy and play.
My Budget is around 8k, im now a working man no time or interest to do stuff like overclocking.
Mouse, Keyboard and Monitor dont need cause getting from friend.
Please advise, thanks!
xiaozozo likes this.
Nautyless is offline   Reply With Quote
Old 20-07-2016, 03:35 PM   #188
ZrE0_Cha0s's Avatar
yes sadly that's the case, but u can still a get a mobo with DDR3 but have to add in another cost to get the wifi dongle or card depending on which mobo u gonna get.
Old 20-07-2016, 03:42 PM   #189
q w e r t ii's Avatar
Asrock H81M -HDS + i5 4590 @358
Kingston DDR3 8Gb @48
Zotac 240GB@99
Total: 505
well im not sure if its a totally new build or upgrade.
but i did reco u just upgrade.
therefore i did reco u to reuse ur case and hdd as well.
edit: all price are quote from PCThemes.
Can a new windows just be installed over my current windows?
I lost both my windows cd and product key
Processor
Intel Core 2 Duo E8500
Mainboard
Gigabyte EP45-UD3R
Graphics Card
Palit GTX260 Sonic
Memory
OCZ PC2-6400 DDR2-800 4GB CL5 Kit (2GBX2)
Display
Dell S2409W 24" Full HD LCD Monitor
Storage
Western Digital Caviar Black 640GB
Optical Storage
Samsung 22X SATA DVD Rewriter
Casing
Thermaltake M9
PSU
Andyson F650W
Audio
Sonic Gear Evo III 2.1 Speaker System
OS
Microsoft Windows Vista Home Premium 64-bit
q w e r t ii is offline   Reply With Quote
Old 20-07-2016, 03:52 PM   #190
ZrE0_Cha0s's Avatar
Hi guys,
woah 8K u sure boh? u can really consider a full water cooling system.
Old 20-07-2016, 03:55 PM   #191
ZrE0_Cha0s's Avatar
well if ur windows key is those normal retail key can reuse on a few pc, but if oem den cant.
but a normal retail key are abit more ex den oem, so if u some how know which one u bought that time, den u can reuse it, otherwise u will still need to get a new key.
Old 20-07-2016, 04:03 PM   #192
8k is an amount im comfortable with but it doesnt mean 8k means confirm spend all the 8k haha, but then again i just want a com i know i can use for maybe several years before i need to bother upgrading again.
i dont mind water cooling if its easy to maintain, however my friend who uses one says he regrets his decision because its a hassle to maintain
Old 20-07-2016, 04:14 PM   #193
ZrE0_Cha0s's Avatar
well if u willing to spend , u can even get a lot of powerful system rig. anyway just letting u know that what u buy now can at most last for 5 years max (yes can be even further but depends on how u can maintain it and some time some stuff have hiccups along the way.)
well WC system aint that easy, but still u can play OC well with such a system.
still im mean up to u if u want WC, got a few shop to reco u otherwise, i just go with a build to meet your budget . but might not be too good for OC.
Old 20-07-2016, 04:17 PM   #194
Haha, thanks, just reco me some builds lor, no need to bother about OC la, at my age, now no time to bother about stuff like OCing, can play at ultra spec enough to make me happy liao haha
Old 20-07-2016, 04:30 PM   #195
Also if u want to know the monitor mouse and keyboard
the Monitor i getting the 27inch dell ultrasharp one, i dont know whats the exact name.
Mouse using razer naga and keyboard also razer blackwidow
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
