HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree54Likes
Reply
LinkBack Thread Tools
Old 25-10-2016, 09:07 PM   #781
MianBaoFren's Avatar
Hi can anyone advice this build? is this casing good? looking to minimise space and looking for red theme.
Gigabyte GA-H110M-DS2 + i5 6400 @364
G.skill 2400Mhz 8GB @55
Palit GeForce GTX 1060 Dual 3GB @ 270' (lazada SG)
Crucial MX300 275GB @112^ (lazada SG)
FSP 550w Hexa @68
Thermaltake Armor A30i Speedy Limited Edition @115
windows10 @reddit
if u die die want that casing it's fine ba.
but i would prefer if u up your i5 to 6500. but that's fine too.
also note that ur mob can only take ram up to 2133mhz.
so that 2400mhz will only run up till that.
since your rig won't take up much power, the 550w psu is not really needed. but i see the price is ok la.
overall, what's your budget?
MianBaoFren is online now   Reply With Quote
Old 25-10-2016, 09:21 PM   #782
ZrE0_Cha0s's Avatar
FSP 550w Hexa @68
windows10 @reddit
but i have not seen this case b4 for some time though, beside that i dunno if u can find that case in local store. (though u have the price)
ZrE0_Cha0s is offline   Reply With Quote
Old 25-10-2016, 09:54 PM   #783
ferocity's Avatar
Can anybody advice which shop in sim lim is recommended for the purpose of installing a rig? I am reusing some parts from my current rig while buying a couple parts online. Will be getting case and psu from the shop and getting them to help me fix up the rig. My main concern would be good cable management. Lastly, whats the approximate labour cost the shops charge for installing a rig?
ferocity is offline   Reply With Quote
Old 25-10-2016, 10:04 PM   #784
ZrE0_Cha0s's Avatar
which shop u buying and as for good cable mgmt maybe still ok for all of them, appx $20~$30
Old 25-10-2016, 11:53 PM   #785
budget roughly ard 900-1k? Would prefer a red theme.
ciraxis83 is offline   Reply With Quote
Old 26-10-2016, 12:17 PM   #786
Hi guys, I'm looking to upgrade my pc RAM to 16GB, setup is Biostar TP67B+ i5-2500k with kingston 4gb RAM.
What RAM should I buy for my MB? Can recommend me cheap place to buy?
Thank you.
Processor
i5 2500k
Mainboard
biostar tp67b+
Graphics Card
sapphire hd5850 xtreme 1gb
Memory
4gb
Display
samsung 22"
Storage
1tb
Optical Storage
lg24x
Casing
ikonik en2
PSU
fsp aurum 600
OS
w7 hp x64
kozalaq is offline   Reply With Quote
Old 26-10-2016, 01:17 PM   #787
ZrE0_Cha0s's Avatar
Thank you.
Just buy 2 x8Gb of Kingston ddr3 1333mhz valueram from tradepac. Else u can consider buying from Amazon and find cheap 1333Mhz ram.
Old 26-10-2016, 01:31 PM   #788
Thanks for reply. Can I use 1600mhz one? cos i see the price is the same.
Also browsing around online stores like qoo10 is cheaper than pricelist from tradepac. Is online one reliable?
Sorry been a while since i update about pc stuff.
Processor
i5 2500k
Mainboard
biostar tp67b+
Graphics Card
Memory
4gb
Display
samsung 22"
Storage
1tb
Optical Storage
lg24x
Casing
ikonik en2
PSU
fsp aurum 600
OS
w7 hp x64
Old 26-10-2016, 01:53 PM   #789
ZrE0_Cha0s's Avatar
I think u can get 1600mhz. Next yes u can get from q10 so long u see their shop location is SG.
Old 27-10-2016, 01:28 AM   #790
Hi all
I am looking to upgrade my current desktop. only need a mid-range desktop for surfing internet and dota 2.
Current specs are i5-2500k @ 3.3GHz, Biostar TP67B+, ATI Radeon HD 5800 Series, 2x Kingston 1333 4gb ram, aurum series 500 gold, lancool tower.
Looking to upgrade to i5-6500 @ 3.2, gigabyte z170x ud3, retain gfx card, 2x pc4-2133 8gb ram, retain PSU and retain lancool tower.
is this doable? TIA
Processor
i5-6500 @ 3.2 with Cooler Master Seidon 120V Plus
Mainboard
MSI B150M Bazooka Plus
Graphics Card
Zotac gtx 1060 3GB
Memory
KVR DDR4-2133MHz 16GB (2X8GB)
Display
Samsung SyncMaster 2333sw
Storage
Toshiba 500gb SSG Sandisk 500GB SSD Transcend 500GB SSD Samsung 1TB HDD
Casing
Fractal-design Define Mini C - Window
PSU
SF Leadex Silver 90+ Full Modular 550W
Audio
Logitech Z623
OS
Microsoft Windows 7 Home Premium (64-bit)
Announcement is offline   Reply With Quote
Old 27-10-2016, 07:48 AM   #791
ZrE0_Cha0s's Avatar
Hi all
is this doable? TIA
Still thinking u should wait for kabylake or Zen to be out and upgrade, but dem again the games u playing is still OK for your current PC though.
Old 27-10-2016, 06:16 PM   #792
Hi guys,
wanna asked that if zotac 1070 8gb mini will runs good in msi bazooka plus +i5 6500 mobo for gaming??
Jackbean is offline   Reply With Quote
Old 27-10-2016, 07:03 PM   #793
ZrE0_Cha0s's Avatar
Hi guys,
still good enough.
Old 27-10-2016, 07:23 PM   #794
Thanks bro. Will wait for new ones to come out then buy.
Processor
Mainboard
Graphics Card
Zotac gtx 1060 3GB
Memory
Display
Storage
Casing
PSU
Audio
Logitech Z623
OS
Old 27-10-2016, 07:59 PM   #795
still good enough.
Hi ZrE0_Cha0s,
Thanks for the reply! Currently zotac 1070 mini on discount quite tempted to buy from q10.
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
