HWZ Forums
Login Register FAQ Mark Forums Read
Buyer's Guide II: Extreme, High-End, Mid-Range, Budget, and Entry Level Systems - Part 3
Like Tree54Likes
Reply
LinkBack Thread Tools
Old 13-07-2016, 12:00 PM   #91
ZrE0_Cha0s's Avatar
What speed should i get for my RAM?
maybe get 3000MHz or 3200MHz, depends on how much OC u wanna play.
ZrE0_Cha0s is online now   Reply With Quote
Old 13-07-2016, 12:04 PM   #92
I can ignore the maximum ram speed listed at intel site for 15-6600k which is 2133?
justin5615 is offline   Reply With Quote
Old 13-07-2016, 12:11 PM   #93
ZrE0_Cha0s's Avatar
well that is the normal speed, or default timing. u can still tweak around to goes beyond it. so long u have intel xmp ram setting u can oc higher.
xiaozozo likes this.
Old 13-07-2016, 12:44 PM   #94
I see, thank you very much
Old 13-07-2016, 03:08 PM   #95
Gigabtyle H97 D3H + i7 4790 @612
Kingston DDR3 Valueram 2x 8GB @96
SF Ledex 550W Sliver @119
ZOTAC T500 240GB SSD @82.90+3
Toshiba 1TB @64
Corsair Spec-01 @79
Total: 1055.90
all prices are quote from PCTheme.
lazada prices are inclusive of shipping.
this is somehow the bare minimum and close to your budget.
well cant really say will u be able to slow down or not...since i have not include the gpu (even though its not really optional and must but still to have as it can help the processing.)
ahh ok thanks, if i push my budget up to 1.3k will it help?
xmrgreenx is offline   Reply With Quote
Old 13-07-2016, 06:02 PM   #96
itx mobo
Hi all,
I'm looking at a new skylake build at the moment, and intending to do a small form factor build.
I don't intend to overclock, and am thinking of going for an i5-6600.
Does anyone have recommendations for a motherboard? Looking to spend under $500.
Have considered the following:
MSI B150I PRO GAMING AC
ASUS B150I PRO GAMING/WIFI/AURA
ASROCK H170M ITX AC
GIGABYTE H170N WIFI
but am not sure which to go with.
I'm going with a single SSD setup, so don't need RAID support.
Does anyone have any experience with the above boards? Also willing to consider other options. Thanks!
lumin87 is online now   Reply With Quote
Old 13-07-2016, 07:03 PM   #97
joshuaho's Avatar
Personally would go for the gigabyte one you stated, since no over clocking needs to be done just getting s basic board is good enuf
Processor
i7 7700k 5.1Ghz (LC & Delid)
Mainboard
Z270i ASUS PRO GAMING
Graphics Card
GTX 1080ti MSI Gaming X 11GB (LC)
Memory
32GB Corsair Vengence 3200Mhz (2x16GB)
Display
ASUS MX27AQ BenQ XL2420T
Storage
Samsung 500GB 960 PRO M.2
Optical Storage
Casing
FRACTAL DESIGN NANO S
PSU
COOLER MASTER V1000
OS
Windows 10 PRO
joshuaho is offline   Reply With Quote
Old 13-07-2016, 08:33 PM   #98
Hi guys, new to building desktop.
My budget is around 1.5k to 1.8+++k.(preferably 1.5k but if really cannot, can extend)
I will be doing Photoshop work and some 3d model work. Also for programming as well. Booting windows and Linux as well. I like to tinker with stuffs so will be nice if I can overclock. Will be buying a graphic card for gaming in december so no graphic card is needed for now.
Required:
16gb
I7k if possible(i5k or just normal i7 is okay if my budget can't do it)?
Wifi
More USB ports the better
Monitor 1080p IPS will do(1440p possible for this budget?lol) <- choice of monitor affects my choice of graphics cards?
One 1TB and one 4TB hdd
Ssd not really a must
Modular PSU
Casing no need to be fancy, can fit everything good enough
I hope I gave enough information. If I don't, kindly tell me! Feel free to correct me if i am wrong. Thank you and I appreciate the help
xavierng12 is offline   Reply With Quote
Old 13-07-2016, 09:58 PM   #99
ZrE0_Cha0s's Avatar
Required:
16gb
Wifi
Modular PSU
MSI Z170A PC MATE + i7 6700k @ 735
G.Skill Ripjaws V 2400Mhz 16GB @125 (not sure if u wana oc ur ram as well or not)
SF Ledex 650W GOLD @159 (Fully Modular)
Toshiba 1TB @64 (Partition it so u can dual boot)
Toshiba 4TB @190
FD Define R5 @149
CM Hyper 212x @69
Total: 1491
All prices are quote from PCthemes, otherwise stated.
some things to note:
1)Wifi not sure which one u want to go :
Asus PCI-E AC56 Dual Band card @99 (PCTheme or USB-AC55 @69 (Mediapro)
2)Monitor is kinda hard unless i skim on the casing or change to a normal i7, but still think u should 1 shot just get those OC parts.
but still up to u.
Old 13-07-2016, 10:33 PM   #100
Toshiba 4TB @190
FD Define R5 @149
CM Hyper 212x @69
Total: 1491
but still up to u.
Thanks chaos! Hmm if my budget goes up to 1.6-1.8k, is is possible to get a monitor?
Old 13-07-2016, 10:50 PM   #101
ZrE0_Cha0s's Avatar
but is ur monitor a gaming one or normal usage? normal usage maye 1.65 ~1.7 can for 1080p, but 1.8k maybe can get 1440p (still prefer if u can wait till comex show on sept, but that is way too long)
Old 13-07-2016, 11:08 PM   #102
Use for both game and normal. 1080p should be enough for me. I just prefer a color accurate one for digital art. Gaming wise,counterstrike and new AAA titles with the desktop I'm getting. Also im getting an AMD graphics card if you need more info for the monitor ports. Thanks (:
Old 14-07-2016, 12:14 PM   #103
ZrE0_Cha0s's Avatar
u can consider getting a Dell S2316H
Old 14-07-2016, 12:29 PM   #104
Need Advice - Graphics Card Upgrade
Hi Experts !
Good Afternoon.
Need to seek you advice as I'm thinking of upgrading my graphics card to GTX 1070 but I'm worried if my MB can support as well as if I'm require to change my power source ?
Current Specs:
INTEL I5-3470 (1155) + COOLER MASTER HYPER 212 EVO CPU COOLER
ASUS P8Z77-V LX (LGA1155)
ASUS 2GB GTX 660TI DIRECT CU II O.C DDR5 PCIE
G SKILL NT PC10600/1333MHZ 4GB DDR3 ( x 2 )
W.D 1TB BLUE 64MB 3.5" SATA3 HDD
SAMSUNG (SYNC MASTER S22B350)
LG 24X SATA DVDRW
SEASONIC M12II MODULAR 620W 80+
SHARKOON T28 ATX CASING
WINDOW 10
Processor
Mainboard
Graphics Card
Memory
Display
Storage
Optical Storage
LG 24X SATA DVDRW
Casing
PSU
OS
WINDOW 10
funnyhercules is offline   Reply With Quote
Old 14-07-2016, 01:26 PM   #105
ZrE0_Cha0s's Avatar
Hi Experts !
Good Afternoon.
Current Specs:
LG 24X SATA DVDRW
WINDOW 10
How old is your psu?
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
Samsung
Rewards
