HWZ Forums
Login Register FAQ Mark Forums Read
gpgt: this kind of ITX casing, how to connect the power?
Reply
LinkBack Thread Tools
Old 08-04-2019, 09:53 AM   #1
Shutterbox's Avatar
Red face gpgt: this kind of ITX casing, how to connect the power?
saw this compact itx casing:
very nice n compact, but:
1) what kind of power supply to use?
2) any itx motherboard can work, or only those with compatibile power connection? ie mother has 24pin, but depending on psu used, can still work with motherboard's 24pin connector?
__________________
上梁不正, 下梁歪
狗官一群, CCB
Processor
Intel E3-1245-V3
Mainboard
MSI B85-G43M
Graphics Card
onboard
Memory
Kingston DDR3-1333Mhz CL9 4 x 4GB
Display
Dell U2412M
Storage
Intel 530 256GB + Hitachi 2TB
Optical Storage
LG BR/HD-DVD combo drive
Casing
Lian Li V354B
PSU
Superflower Goldern Green 500W
Audio
-onboard
OS
Win10
Shutterbox is offline   Reply With Quote
Old 08-04-2019, 10:13 AM   #2
1. Check the specs, you need to know the maximum dimension for the PSU, so that you can fit into the case.
2. Only Mini-ITX (170mm x 170mm).
__________________
Planning for your new Smart Home? We can assist you - AwfullySmart.com
AwfullySmart is offline   Reply With Quote
Old 08-04-2019, 10:16 AM   #3
Shahmatt's Avatar
The PSU for normal desktop PC has two components. The first is the AC-DC unit which converts the AC 220V to either a 12V or 19V DC current. The second is a DC-ATX unit, which splits the current to the various wires needed for mobo, HDD etc.
For this type of case the PSU is split into the two components. The DC-ATX is inside the case, but the AC-DC is outside the case. AC-DC can be a suitable laptop adapter.
Usually AC-DC is very compact. Sometimes it is mounted in one corner of the case. Sometimes it is mounted on the 24pin plug itself (example search for pico PSU).
The DC-ATX will receive power from a laptop style power connector in the case. So all you have to do is plug in a suitable laptop adapter to power the PC.
Processor
2200G @ 3400/stock cooling LLC8
Mainboard
MSI B350i Pro AC ITX
Graphics Card
Vega 8 1525MHz @ 1.2250V
Memory
HyperX Fury 2x4GB 3333@16-17-17-17-32 1.35V
Display
LG 25UM58 (21:9 ultrawide)
Storage
Transcend MTE820 128GB NVMe m.2, Seagate FireCuda 2TB 2.5"
Casing
Realan E-W80 (3.6L) + adapter (0.5L) = 4.1L
PSU
Pico-box X300 DC-ATX + 180W 19V adapter
Audio
on-board + Creative T3
Shahmatt is offline   Reply With Quote
Old 08-04-2019, 10:16 AM   #4
Shutterbox's Avatar
no specs shown in description, but i doubt even sfx psu can fit in.
from pic there is no slot for backplane of psu's power connector and on/off switch
__________________
上梁不正, 下梁歪
狗官一群, CCB
Processor
Intel E3-1245-V3
Mainboard
MSI B85-G43M
Graphics Card
onboard
Memory
Display
Dell U2412M
Storage
Optical Storage
Casing
Lian Li V354B
PSU
Audio
-onboard
OS
Win10
Old 08-04-2019, 10:20 AM   #5
Shahmatt's Avatar
Further to my last message. You can also get a "Thin" mini ITX type mobod which accepts DC power directly from a laptop adapter (no separate DC-ATX unit). These will have the power socket in the motherboard I/O plate directly and there is no separate connector.
Processor
Mainboard
Graphics Card
Memory
Display
Storage
Casing
PSU
Audio
Old 08-04-2019, 10:27 AM   #6
Shahmatt's Avatar
http://www.minicase.net/product_E-W60.html
Scroll down to LR1204 internal powerboard to see example DC-ATX unit which will be inside the case.
Processor
Mainboard
Graphics Card
Memory
Display
Storage
Casing
PSU
Audio
Old 09-04-2019, 04:18 AM   #7
Any ITX mobo can work. This case doesn't have space to put a 1U flex psu, you'll be using a 150w pico PSU (or generic brands) with an external power brick for it.
Processor
Ryzen 5 2600
Mainboard
ASRock AB350 Gaming K4
Graphics Card
MSI RX 580 8GB
Memory
2x8GB 3200mhz CL15 crucial ddr4
Storage
500gb samsung 860 evo m.2 / 3TB HDD
OS
Windows 10 Pro
averdant is offline   Reply With Quote
Old 09-04-2019, 07:57 AM   #8
klap_hanz's Avatar
Google HDplex or Pico PSU
Processor
Intel i7-3770T
Mainboard
Gigabyte B75M-HD3
Graphics Card
Gigabyte GTX 660
Memory
Crucial 16GB DDR3-1600Mhz
Display
Dell 23" LCD Monitor
Storage
Samsung 840 EVO 250GB SSD & Toshiba 3TB HDD
Optical Storage
Asus 16X BD-ROM
Casing
Aerocool DS Cube
PSU
Seasonic G-450W
Audio
Realtek (Onboard)
OS
Hackintosh Yosemite 10.10.5
klap_hanz is offline   Reply With Quote
Old 09-04-2019, 11:22 AM   #9
terry1's Avatar
i think you may need these two items. note that this is not your usual laptop power adapter
https://www.amazon.com/Mini-Box-pico...s%2C365&sr=8-3
https://www.amazon.com/Switching-Sup...RX36PQCFNPPXGC
terry1 is offline   Reply With Quote
Old 09-04-2019, 11:37 AM   #10
alamakazim's Avatar
yes... this should come with it... or even not because of different power rating
need to study your board consumption
__________________
阿拉妈卡砸 - ALAMAKAZAM
Selling CD , dragonball etc
https://tinyurl.com/lj9rmdx
Processor
i5 3470
Mainboard
asrock h77 pro4/mvp
Graphics Card
R7 200
Memory
16gb niah
Display
Philips BDM4065UC 40" 4K Monitor
Storage
few SSDs...
Optical Storage
bluray
Casing
Antec P180
PSU
Super Flower Leadex Gold 750w
Audio
Red Wine Audio Bellina Pro > Signature 16 > Harbeth P3ESR
OS
Windows 7
alamakazim is offline   Reply With Quote
Old 09-04-2019, 11:46 AM   #11
terry1's Avatar
what power rating you buy would depend on what cpu you have
Old 09-04-2019, 12:15 PM   #12
Shutterbox's Avatar
such small setup means no gaming
only a compact chassis for general PC use, so if its reasonably value setup would be like a
Asrock Fatal1ty B450 Gaming-ITX/ac with R3 2200G and a NVMe SSD + 1 more 2.5" drive if needed
__________________
上梁不正, 下梁歪
狗官一群, CCB
Processor
Intel E3-1245-V3
Mainboard
MSI B85-G43M
Graphics Card
onboard
Memory
Display
Dell U2412M
Storage
Optical Storage
Casing
Lian Li V354B
PSU
Audio
-onboard
OS
Win10
Old 09-04-2019, 05:57 PM   #13
This small setup is good enough for MOBA gaming like Dota 2. I have such a setup with a 2200GE + iGPU lightly OC-ed to 1300mhz I use for portable gaming. You can also underclock + undervolt a 2200G while overclocking the iGPU to get the same setup as me.
Using a m.2 sata ssd would be better since it's cheaper, no point getting nvme if you're not going to be writing large files regularly.
Processor
Ryzen 5 2600
Mainboard
Graphics Card
MSI RX 580 8GB
Memory
Storage
OS
Windows 10 Pro
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
