HWZ Forums
Login Register FAQ Mark Forums Read
Power Supply Buyer's Guide
Like Tree5Likes
Reply
LinkBack Thread Tools
Old 28-01-2013, 09:00 PM   #316
adrianlee's Avatar
PC Power & Cooling Silencer MK III 750W Power Supply Review
PC Power & Cooling Silencer MK III 750 W Review | techPowerUp
adrianlee is offline   Reply With Quote
Old 29-01-2013, 03:20 PM   #317
Need a PSU replacement
Hi,
I just fried my new PSU that I bought back from Taiwan.
Forgot to change the voltage switch before powering on.
The dimensions are 12cm x 10cm x 6cm.
Anyone knows which PSU I can buy to replace?
I still like my casing...
If anyone has any suggestions, don't mind just PM me.
Thank you very much!
Regards,
Edric
edricting is offline   Reply With Quote
Old 06-02-2013, 09:24 PM   #318
adrianlee's Avatar
Seasonic X-650 KM3 650W Review
Old 05-04-2013, 09:20 PM   #319
I have a Seasonic M12II-620 power supply. I am going to get a GTX 690 graphics card.
For the graphics card to work using the power supply, I'll need to use some molex adaptors, because the power supply only has one 6 pin and 8 pin power connectors, but the graphics card needs two 8 pin power connectors.
The rest of the system is a 2600k (assume it's overclocked although I doubt it), two SSDs, three hard disks, dvd writer, various peripherals.
Should I get a replacement power supply? I'd rather not unless there will be short or long term detrimental effects, can't be bothered to rewire.
xand is offline   Reply With Quote
Old 06-04-2013, 01:16 PM   #320
Hi,
Regards,
Edric
If lucky, may be just fuse blow.
cscs3 is offline   Reply With Quote
Old 23-04-2013, 06:53 PM   #321
adrianlee's Avatar
PC Power & Cooling Silencer Mk III 850W Power Supply Review
Not too long ago, I took a look at a new PC Power and Cooling unit that turned out to be just plain awesome: the Silencer Mark III 1200 watt unit. Today, I'm looking at the little brother of that unit, the 850 watt model. We'll find out today if this 80 Plus Gold unit can match up to the high standards set by the flagship of the line.
PC Power & Cooling Silencer Mk III 850W Review
Enermax Triathlor FC 650W Power Supply Review
Recently, we took a peek at a new case from Enermax called the Giant Ostrog. Today, we're looking at an Enermax power supply you may choose to use inside that case, the Triathlor FC 650W. This is a budget minded 650 watter that still brings such features as semi-modularity and 80 Plus Bronze certification to those of us who cannot afford the better and more expensive models. Let's see what it's like, shall we?
Enermax Triathlor FC 650W Review
Corsair AX and AXi Series Power Supplies Review: Small Letter Big Difference?
Today we are going to check out two pairs of “Platinum” power supply units with capacities of 760 and 860 watts, which belong to two different series: AX and AXi. Which one should be a preference for those who are looking for the most efficient power source for their systems?
Corsair AX and AXi Series Power Supplies Review: Small Letter Big Difference? - X-bit labs
Old 23-04-2013, 09:24 PM   #322
temasekcity's Avatar
Use 220V to power 110V, you should hear a loud explosion before it dies peacefully in front of you.
A2yincor likes this.
__________________
Quitters dun win. Winners dun quit.
temasekcity is offline   Reply With Quote
Old 26-04-2013, 08:22 PM   #323
adrianlee's Avatar
Corsair CX Series Modular CX600M 600W Power Supply Review
Corsair CX Series Modular CX600M 600 W Review | techPowerUp
What is the best 720-750W Power Supply?
What is the best 720-750W Power Supply? | bit-tech.net
Old 07-05-2013, 12:21 PM   #324
adrianlee's Avatar
Super Flower Leadex 1000W Review
Not very long ago, Super Flower wasn't really a name on anyone's radar screen. They made decent units to be sure, but they were just kind of there. Then, someone over at SF headquarters woke up, saw the latest awesome unit out there, and said, "wait a minute, I bet we can do that, too." The Golden Green platform came out and started turning heads, but Super Flower didn't stop there. With the new 80 Plus Platinum efficiency certification level, the Golden King platform came out and turned even more heads. Now, Super Flower would like me to test the new Leadex platform. This is the next step in their journey for dominance at the top of the power supply game. Let's find out how well they pulled it off.
Enermax NAXN ADV 650W Power Supply Review
Enermax, although not one of the biggest PSU OEMs (e.g. like Delta), still manages to offer products of very high quality and performance. Their own creations are unfortunately more expensive than those of the competition because a medium-volume production line doesn't allow for reduced production costs, which seriously influences retail prices. This is most likely the main reason behind their mainstream and mid-range units by other OEMs, since doing so allows them to offer really affordable PSUs that easily meet the tough competition in this hotly competed for category. You see, high-end units may be a manufacturer's pride, but they don't sell en masse. They definitely don't pay the bills.
The previous NAXN units were mostly made by Channel Well Technology (CWT)—the two stronger models were made by Sirtec. Enermax was, as it seems, left quite satisfied by CWT since this OEM has also manufactured the new NAXN ADV line. The aforementioned line includes three members with capacities ranging from 450 W to 650 W, and all of them feature a non-modular cabling design.
In this review, we will take a good look at the strongest of the NAXN ADV units. This NAXN ADV has a capacity of 650 W, and its model number is ETL650AWT. This unit have a non-modular cabling design, is 80 Plus Bronze certified, has a single +12V rail, is ErP Lot 6 2013 ready, and has a compact footprint.
http://www.techpowerup.com/reviews/E...L650AWT/1.html
Old 14-08-2013, 03:23 PM   #325
adrianlee's Avatar
Super Flower Leadex Platinum 1000 W Review | techPowerUp
EVGA Supernova G2 1300W Review
EVGA Supernova G2 1300W Review - jonnyGURU Forums
http://www.techpowerup.com/reviews/E...rNOVA_G2_1300/
Old 31-08-2013, 06:36 PM   #326
adrianlee's Avatar
EVGA 500B 500W Power Supply Review
EVGA 500B 500W Review
EVGA Bronze 500 W Review | techPowerUp
Old 04-09-2013, 09:00 PM   #327
adrianlee's Avatar
Antec High Current Pro HCP-850 Platinum PSU Review
Summary
In the HCP-850 Platinum, Antec took an already excellent design and made it practically unbeatable. This beast is pretty well unmatched for performance right now, coming in here and just obliterating the competition with unreal stability and ripple control. Only two current platforms I can think of can even come close to this - the Seasonic KM3 and Super Flower Leadex. But, neither one of them quite has either the rail stability or ripple suppression both to match this one. I just wish the price was a bit lower. As it stands right now, though, you can't really do any better than this bad boy. We're at the top of the mountain... at least for now.
Antec HCP-850 Platinum Review
Old 02-10-2013, 09:13 AM   #328
adrianlee's Avatar
Corsair RM Series 550W Power Supply Review
Corsair RM Series 550W Power Supply Review @ PC Perspective
Corsair RM Series 750W Power Supply Review
Corsair RM Series 750W Power Supply Review | HEXUS.net
Corsair RM Series 850W Power Supply Review
Corsair RM Series 850W Power Supply Review | techPowerUp
Seasonic M12 II Evo Edition 850W Power Supply Review
Seasonic M12 II Evo Edition 850W Review |Jonnyguru
Seasonic M12 II Evo Edition 850W Review | Kitguru
KingJio likes this.
Old 28-01-2014, 06:35 PM   #329
adrianlee's Avatar
Not long ago, we took a look at our first RM series unit from Corsair, the RM650. Today, we'll be looking at big brother - the 850 watt model. This is a unit that bears very little in common with its smaller sibling, as it is a completely different platform from a completely different OEM. Let's have at it.
http://www.jonnyguru.com/modules.php...Story&reid=369
Super Flower Leadex Gold 750W Power Supply Review
Super Flower comes to us today with their Leadex Gold 750 watt model today. We've already seen that this platform is nigh unbeatable at higher power levels, but what about the low end of the scale? Will it turn out to be better or worse or the same? Let's find out.
Super Flower Leadex Gold 750W Review
KingJio likes this.
Old 07-05-2014, 08:05 PM   #330
RMA Psu FSP Aurum
Rma a FSP Aurum 400w 80+ bronze ,5 yr warranty but power degraded on the 3rd yr so rma. Was given 2 option
1) free 1 to 1 exchange to same model reflurish unit (look old to me)
2) top up $45 for 550w 92+ platinium with 2 yr warranty from now. (which my warranty still got 2 yr more for 400w 80+ bronze )
which is better deal ?
__________________
[SIZE=1][/SIZE]
tmengyew is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
