www.hardwarezone.com.sg
www.hardwarezone.com.sg (/)
-   HardwareZone.com Reviews Lab (online publication) (https://forums.hardwarezone.com.sg/hardwarezone-com-reviews-lab-online-publication-26/)
-   -   Xiaomi 45W USB-C power adapter review (https://forums.hardwarezone.com.sg/hardwarezone-com-reviews-lab-online-publication-26/xiaomi-45w-usb-c-power-adapter-review-5864513.html)
kitsura 10-07-2018 07:05 PM
May i know what was the setup used to charge the iPad Pro 12.9"? I'm using the Xiaomi 45W charger with the Apple USB-C to lightning cable and charging my 2015 iPad Pro 12.9" and can't get it to charge any faster than the normal Apple adaptor.
yusoffb01 12-07-2018 08:57 AM
apple is slow to adapt faster charging standard.
chucks 08-08-2018 02:42 PM
Quote:
I used Apple's own USB-C to Lightning cable too. I no longer have the charger with me, but this sounds like one of the devices doesn't recognize the other, thus causing fast charging to not start. You can try:
1.) Removing and reinserting the C end of the cable when you notice it isn't fast charging to force a re-detection
2.) Flip over the cable's C connector and plug it into the charger again
3.) Turn off the charger and turn it on again
In short, many third parties use their own methods to enable charging support for Apple devices. This can lead to improper detection. There is no sure-fire way to solve this - sometimes, plug out/plug in the cable again helps; sometimes, flipping the connector helps; and sometimes, turning the power off (or on) before plugging in the cable helps.
racketrestringerr 09-09-2018 03:22 PM
Agree with yours !
racketrestringerr 09-09-2018 03:24 PM
Quite laggy when using after sometimes ,but such price are giving such quality can't expect too much. I only like the screen bigger.
kitsura 14-09-2018 11:03 PM
Quote:
I found the problem. At a certain point, Apple updated iOS to detect if the charger used is 3rd party or Apple's own charger. All 3rd party chargers are now only able to charge at normal speeds. I have switched to an Apple USB-C charger and am able to get fast charge speeds.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Copyright © SPH Magazines Pte Ltd. All rights reserved.
