www.hardwarezone.com.sg
www.hardwarezone.com.sg (/)
-   Headphones, Earphones and Portable Media Devices (https://forums.hardwarezone.com.sg/headphones-earphones-portable-media-devices-314/)
-   -   [Need Advice] Fiio Q1 MK II or Sound BlasterX G6? (https://forums.hardwarezone.com.sg/headphones-earphones-portable-media-devices-314/%5Bneed-advice%5D-fiio-q1-mk-ii-sound-blasterx-g6-6310964.html)
Cut_throat 17-06-2020 04:53 AM
Hi I've been using Sound Blaster Digital Music Premium HD for six years now. I'm looking for an upgrade for use on PC/Android with IEM (KZ AS10/AS16) for listen.
Should I get Fiio Q1 MK II or Sound BlasterX G6? Thanks.
xenocide 17-06-2020 01:23 PM
i've also been using the Creative Premium HD for years and its been good.
also recently thinking of upgrading and portable/desktop amp also come to mind.
but i'm not sure the everyday plug in and plug out will have any issues?
end of the day, i know i might still get a desktop amp :s13:
Cut_throat 18-06-2020 03:54 AM
I ordered one Fiio Q1 MK.II ytd. I think I'll receive it today in the afternoon. I researched ppl say there's no difference between Q1 MK.II and K3 (Desktop DAC). So I went with the Q1 MK.II so it can work with my phone as well Type C OTG for DSD files.
koroshiya8 20-06-2020 10:23 AM
There is now 15% off selected Soundblaster SoundCard but need to give an exissting soundblaster soundcard as upgrade.. i just pay $8 in carousell for a 2nd hand one and then bought the AE-9
https://sg.creative.com/upgrade/
https://i.imgur.com/ruTAkTU.jpg
https://i.imgur.com/86zmozq.jpg
https://i.imgur.com/jJvXk1W.jpg
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright © SPH Magazines Pte Ltd. All rights reserved.
