HWZ Forums
Login Register FAQ Mark Forums Read
Audio technica M40x with sound blaster e1
Reply
LinkBack Thread Tools
Old 28-09-2014, 02:12 PM   #1
tinky123's Avatar
Hi ppl. Need your advice. Do you think i should get an e1 sound blaster? I have a m40x already.
__________________
挥一挥衣袖
带走一片云彩
tinky123 is offline   Reply With Quote
Old 28-09-2014, 02:42 PM   #2
bangdoll's Avatar
M40X is quite flat (lifeless as some said), but will benefit with a decent amp.
Read the link for a rough idea about the E1.
__________________
Run.Gun.Kill.
bangdoll is offline   Reply With Quote
Old 28-09-2014, 03:28 PM   #3
tinky123's Avatar
so do you think i should get the e1 amp? is it good enough for the m40x?
__________________
挥一挥衣袖
带走一片云彩
Old 28-09-2014, 04:11 PM   #4
it will have the same effect as the salt tablet given by your doc when you have a flu.
You will feel livelier, more umphs, and more shiok, can suddenly can do what you could not have achieve...
IMHO....
pions2000 is offline   Reply With Quote
Old 29-09-2014, 11:24 AM   #5
Suspended
Better to try first the combo, bro; good if you have friends who own the E1. If you are contented with the sound of ATH-M40X alone, then perhaps you can enjoy it first. I'm sure there is something about it that you've liked that's why you got it in the first place. But if you feel something's lacking over period of time, or want to have a change in sound or even upgrade, then consider adding up some gears.
TeamStereo is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
