HWZ Forums
Login Register FAQ Mark Forums Read
(Help) setting when connected to dac
Reply
LinkBack Thread Tools
Old 17-03-2016, 02:09 AM   #1
Anyone can enlighten me, am currently using sony walkman a20 series. Do i need to enable the DSEE HX & clear audio also the EQ? Or should i disable all n let the dac do the job?
junhao10 is offline   Reply With Quote
Old 17-03-2016, 10:30 AM   #2
ewng's Avatar
It's up to you...if you like to enable those functions then just enable them...after all it's you who listen to it...not us...
ewng is offline   Reply With Quote
Old 17-03-2016, 10:41 AM   #3
fumoffuXx's Avatar
so free, im watching you.......
__________________
Esther is her name, music is my gain.
fumoffuXx is offline   Reply With Quote
Old 17-03-2016, 03:17 PM   #4
ewng's Avatar
Piang...you so creepy sia...
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
