HWZ Forums
Login Register FAQ Mark Forums Read
Should I get a 3.5mm head or 2.5mm TRRS head with 3.5mm adapter for upgrad cable
Reply
LinkBack Thread Tools
Old 24-11-2016, 12:20 PM   #1
blazin's Avatar
I going to hoot the ALO Ref8 cable.
But can Pro here tell me should I get a 3.5mm head or 2.5mm TRRS head with 3.5mm adapter.
So I can use balanced when I happened to get a player with that TRRS port in the future.
__________________
Canon 7D | 15-85mm | 50mm f1.8 | Σ 35mm f1.4 | 580EXII
http://www.flickr.com/photos/blazinbeat/
blazin is offline   Reply With Quote
Old 24-11-2016, 01:45 PM   #2
xuan87's Avatar
Since more players use the 2.5mm TRRS socket than the 3.5mm TRRS socket, I feel that getting the 2.5 TRRS plug will be the safer bet.
xuan87 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
