HWZ Forums
Login Register FAQ Mark Forums Read
Sony unveils WF-1000XM3 truly wireless noise-cancelling earbuds
Like Tree52Likes
Reply
LinkBack Thread Tools
Old 13-07-2019, 03:42 PM   #46
Only 2 sets silver left at Wisma Atrium branch
coldkey is offline   Reply With Quote
Old 13-07-2019, 09:31 PM   #47
fongwk8's Avatar
Here are my initial thoughts after using it for an hour or two. I bought this because of the ANC, true wireless and Sony sound.
Noise cancellation - Very good. I compared this with the QC20. The QC20 is good at reducing low frequency sound like engine noise, but it does not do a good job at reducing the sound of people taking. With this earphones, it does a good job at reducing noise from both ends of the spectrum. The sound of people talking was reduced dramatically relative to the QC20. With low frequency noise, the QC20 was fractionally better. Roadside noise was significantly reduced although not totally when standing on a pavement. I think Sony really delivered on noise cancellation.
Blinking LEDs - I don't know the rationale behind the blinking LEDs when the earbuds are in use. When I use it at night, anyone and everyone will notice the two blinking LEDs. Sony should offer the option of stopping the LEDs from blinking when the buds are in use.
Sound - Source is ALAC files converted from AIFF files i.e. CD quality. Typical Sony kind of sound i.e. controlled bass. Definitely nowhere near $300+ Sony wired earphones standard, but very good considering it is AAC. I could not quite tell the difference with and without DSEE HX. My head tells me it sounds better with it turned on, but that might just be me being aware that it should sound better as opposed to actually hearing a discernible difference.
Fit - Very good for a earbud that sticks out. The extra bump helps as it allows the earbud to rest on the ear so I don't get the feeling that it will fall out. I used the largest silicon tip as the smaller sized ones did not provide any seal. As a guide, the largest tip feels a little larger than the L sized Sony silicon tips (light green) in terms of diameter and is definitely longer. I replaced it with the L sized silicon tips and the earbuds still fit. Comfort will depend on the shape of the ear so you will need to teat this out yourself.
Looks - It sticks out. It looks like bluetooth earphones from 10 years ago or longer, not the stealthy earbuds that are buried into the ear.
Call quality - Have not tested it. Will try doing it over the weekend.
Connection - Have not experienced dropping connections. I used this with an iPhone 8 plus. Need to test in crowded places.
I think it is fair to mention the following at this juncture.
1. If one is not looking for ANC, this is NOT the earphones for you. The money can be spent elsewhere.
2. If one is looking for earphones for sports, this is not for you, not because it is not IPX4 rated, just that I don't think it will be secure enough.
3. If one needs to look cool, look else where. The blinking LEDs and the way it sticks out looks totally UNCLE. I can carry that look so it is still alright for me.
4. If one is looking for ANC above all else, you can consider this. Not all ANC is the same, we see that even with wired earphones. The QC20 stands above all, and this earphones is comparable. Because ANC works well to reduce sound of people talking, I think this is pretty good for office use.
These are just my initial thoughts. Sorry, cannot be more technical about it as I only have a Primary 6 vocabulary.
Oh, mine doesn't blink after I put it into my ears. When I took it out of the case, the blinking was there until it went into my ears (as I didn't see the blinking blue leds when I look at myself in the mirror).
Ran 30 mins on the treadmill today at 10km/h speed, the earphones didn't drop out nor did I need to readjust them during the run. So I guess the concern is still about sweat soaking in the earphones though.
__________________
Visit my Flickr at www.flickr.com/kitonium
fongwk8 is offline   Reply With Quote
Old 13-07-2019, 09:33 PM   #48
fongwk8's Avatar
The only downside I felt with the earphones is... There's no way to see how much battery is left in the charging case. There's only 1 red LED to show you the "charging earphones" or "case is being charged" status.
__________________
Old 13-07-2019, 10:58 PM   #49
This is strange. Mine was blinking blue yesterday. When I read your comment, I put it on to teat and noticed the blinking has stopped. I wonder why.
parchiao is offline   Reply With Quote
Old 14-07-2019, 08:56 AM   #50
fongwk8's Avatar
Haha! When I first noticed the blinking LEDs... I was like "oh no! this set of earphones are going to look like some cheap china earphones!". But am glad that it stopped blinking when it was worn.
Did a search and noted that the number of blinks actually mean something: https://helpguide.sony.net/mdr/wf100...002289866.html
__________________
Old 14-07-2019, 09:24 AM   #51
Tried it out at Connect-IT yesterday. The ANC didn't seem to add much beyond a good passive IEM - compared it with my Aviot and both gave the same amount of isolation.
leecming is offline   Reply With Quote
Old 14-07-2019, 09:57 AM   #52
fongwk8's Avatar
I hope you got the ANC mode on, as there are 3 modes: ANC on, ambient sound (which allows you to hear a "digitised exterior noise" and ambient sound control off (this is just pure isolation, with no ANC).
Yeah, it doesn't work well with cancelling music (like music in the gym or at a mall), but it works extremely well cancelling the vehicle road noise (when i was waiting for traffic light at orchard road), on the bus and on the train. I would be lying if i said that it cancels 100%, but i still hear about 10% of the train/bus/vehicle noise.
ANC doesn't cancel train announcements too, so the train station announcements are relatively loud.
For the first time, the volume of my earphones are kept in the middle-range. Before this, I was listening on the Samsung Gear IconX (which is isolation only), the volume are mostly at 75% or 90% for me to listen well.
__________________
Old 14-07-2019, 10:06 AM   #53
Cheese Steak's Avatar
Which connect-it branch did u try it at?
Cheese Steak is offline   Reply With Quote
Old 14-07-2019, 10:13 AM   #54
Yup. You are right as I have the WH-1000XM3.
If you just activate the ANC you can also hear the rushing sound of the train as it enters the tunnel. Besides that you can also hear people talking but very soft. Watching movies is particularly noticeable. Hearing music will be different for you can increase the volume by a notch so you'll be submerged in hearing your music only without outside noise.
I do hope the next SONY ANC headphone/earbuds can perform better to reduce the outside noise further
Apparatus is offline   Reply With Quote
Old 14-07-2019, 10:18 AM   #55
One annoyance with the ambient sound control on the left ear, the button seems very sensitive to the duration of the tap. Anything more than a light tap will be interpreted as a signal to lower the music for chat mode.
Hope they will update the software to allow a normal tap duration.
On the ANC, if you want complete isolation, you should probably look at WH-1000XM3 instead, I tested that at a PC show and it silenced the loud music blasting from a nearby speaker.
For the WF-1000XM3, it seems to be more focus on reducing ambient noise than all sounds. I did a test with playing different sounds on youtube on a loud speaker (0.5m away) and turning on and off ANC. At 50 percent volume on light music, no loud bass,
A better test will be to try it on bus or MRT, since it is where it will be predominantly used.
Old 14-07-2019, 10:21 AM   #56
fongwk8's Avatar
I tried to get the Comply TrueGrip foam ear tips (hope to improve the isolation), but its too loose for this new model. The Comply TrueGrip is stated as compatible with the WF-1000X though. I guess I'll have to wait a while for Comply to make suitable tips for this model.
__________________
Old 14-07-2019, 10:24 AM   #57
fongwk8's Avatar
Wah, you power leh, use youtube train video to test the earphones!
I noticed that when ANC is turned on, it is more quiet than the "ambient control off" (which is purely isolation).
I also noticed that this earphones perform poorly in windy situations. The wind was blowing and I could hear the wind quite loudly. Anyone experience this too?
__________________
Old 14-07-2019, 10:33 AM   #58
Orchard.
Yeah I tried all the modes - ANC mode, ambient sound, and ANC off. The store had a lot of background noise - people talking, music on speakers. I didn't really hear that much of a difference with ANC on and off which is a problem.
Probably works better for commute (low constant background noise) but might as well just get TWS IEM with a good seal.
Old 14-07-2019, 10:36 AM   #59
Have you try those Dekoni tips?
Old 14-07-2019, 10:42 AM   #60
fongwk8's Avatar
Have you try those Dekoni buds?
No leh. Where can I find demo sets in SG?
__________________
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
