HWZ Forums
Login Register FAQ Mark Forums Read
Sony unveils WF-1000XM3 truly wireless noise-cancelling earbuds
Like Tree81Likes
Reply
LinkBack Thread Tools
Old 27-08-2019, 01:57 PM   #781
tohchr's Avatar
what version?
tohchr is offline   Reply With Quote
Old 27-08-2019, 02:35 PM   #782
carlover76's Avatar
what version?
Version 1.3.0.
__________________
Phone : Xperia Xperia 1 (Purple)
Tablet : Xperia Z4 Tablet (Black)
carlover76 is offline   Reply With Quote
Old 27-08-2019, 02:58 PM   #783
Does the software updates something in the earbuds or just simply a software update only?
~Dragonite~ likes this.
Apparatus is offline   Reply With Quote
Old 27-08-2019, 04:17 PM   #784
carlover76's Avatar
Yes, it will update onto the earbuds as you need sufficient battery in order for the update to take place.
There is information on Sony Website as well :
https://www.sony.com.sg/electronics/...evant_products
__________________
Old 27-08-2019, 04:24 PM   #785
Any noticeable changes post-update?
roetube is offline   Reply With Quote
Old 27-08-2019, 04:45 PM   #786
carlover76's Avatar
No significant difference since the update does not affect anything unless you are pairing with your Windows 10.
Benefits and improvements
Improves connectivity with Windows 10, resolving an issue where on some specific builds of Windows 10, sound would not playback after Bluetooth pairing
General performance and stability improvements
__________________
Old 27-08-2019, 05:43 PM   #787
Gizamo's Avatar
Noise cancelling seems to be better, less wind noise. Anyone can confirm?
Gizamo is offline   Reply With Quote
Old 27-08-2019, 06:57 PM   #788
Thank you
carlover76 likes this.
Old 28-08-2019, 08:07 AM   #789
From Connect-IT or Stereo Qoo10 store
Have local warranty
Which seller do u all buy from in Qoo10..?
Mostly are export set right?
No warranty in SG.
MZeee18 is offline   Reply With Quote
Old 28-08-2019, 08:28 AM   #790
lDuckRicel's Avatar
yup, got problem connecting to my laptop running Windows 10pro Build 1903. hopefully will resolve the connecting issue
__________________
~漂亮女人说的话不可相信,越好看的女人越会骗人~
lDuckRicel is offline   Reply With Quote
Old 28-08-2019, 08:34 AM   #791
lDuckRicel's Avatar
Just to share that the White Silicon Case is very nice as it will glow in the dark.
Anyone needs the $30 voucher, please PM me your Email Address - 1st come 1st get it.
mine silicon case came, they sent me wrong color, same as yours glow in the dark de....
__________________
Old 28-08-2019, 10:04 AM   #792
WestGuy's Avatar
Could be a blessing in disguise if u complain and they ask you to keep or refund you while they send you your correct color?
WestGuy is offline   Reply With Quote
Old 28-08-2019, 10:35 AM   #793
lDuckRicel's Avatar
nvm liao, just use as it is, dun want to go thru the troubles just for the colors when the item is usable
__________________
Old 28-08-2019, 10:42 AM   #794
civicguy's Avatar
Is this normal ? One side 70%. One side 100%. Ha
civicguy is online now   Reply With Quote
Old 28-08-2019, 10:45 AM   #795
DigDub's Avatar
Got wrap also.
DigDub is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
