mamboeidos
- Jan 20, 2008
Wah... Damn sian man a not be replace...
Guys I lost my charging case, anything I can do?
Otherwise I need to throw it away....
Battery life wise, Sony. Design wise, Sony. Noise cancellation not known yet. Sound quality wise, my bet is Sony again. Price wise, Sony.
Anyone’s earbuds keeps getting loose while walking? Can’t seem to get a good fit with their eartips
Ya man, left it charging in hotel, think the Cleaners threw it...
Just received mine today. Still trying to fig out changing the noise cancellation.
Connect to my desktop and its connect but no sound then finally manage to get sound, after a while no sound. Anyone know wats the issue?
Played around and found out need to set left set to control ambience sound.Left tap once means ambience sound. Tap again means ambience sound off. Tap again will go noise cancellation. Press and hold will temporarily get ambience sound until you release your finger.
For your computer try rebooting computer again. Ensure your ear bud are version 1.3.0 (check version by downloading the Sony headphones software )
Hi everyone. Just received mine yesterday. Realized my left bud, when press upon gently. Theres creaking sound. Like loose on the plate/earphone. Anyone experience this on their earphones?
New update. Hope it will be better.
But long saga of repairing my old one. I repaired it twice but still disconnects. Got a 1 for 1 and testing the new one. Seems to work much better for now.
Should i send in for a check or replacement? If yes. Where to send to?
313. Did you drop your bud?
