HWZ Forums
Login Register FAQ Mark Forums Read
Sony unveils WF-1000XM3 truly wireless noise-cancelling earbuds
Like Tree81Likes
Reply
LinkBack Thread Tools
Old 09-09-2019, 06:43 PM   #901
vengence_angels's Avatar
Problem with sennheiser was with the battery leak.
There were a few times when I took the earbuds out only to realise that the battery was flat.
Apparently, the earbuds doesn’t turn off when u place them in the charging case that has no charge left.
Firmware updates did not solve the problem for me and Sennheiser also has no solution. So I had to sell it away.
I prefer the sound quality of the Sennheiser as compared to Sony. But the ANC really is what I enjoy about the Sony.
How bad is the momentum battery life for you to give up the sound quality?
Sent from Samsung SM-N975F using GAGT
vengence_angels is offline   Reply With Quote
Old 09-09-2019, 07:30 PM   #902
Couldn’t have said it any better. I always feel insecure knowing that I can go out to work, to play music while commuting only to realise there’s no batt. Then I’ll have to give it a quick charge then it’ll be usable.
I settled for Sony after trying it out for a week and sold off my Sennheiser. The audio is still superb but Sony audio is still acceptable to me plus the battery is a winner
MZeee18 is offline   Reply With Quote
Old 09-09-2019, 08:22 PM   #903
Anyone knows when the next wave of stock will be coming to SG?
hamikua is offline   Reply With Quote
Old 09-09-2019, 08:24 PM   #904
So crazy, 8pm flash sales, sold out by 810pm and this is export set, no local warranty
https://www.lazada.sg/products/pre-o...806850755.html
SuperDecker is online now   Reply With Quote
Old 09-09-2019, 08:42 PM   #905
Anyone bought from this seller? Tempting
https://www.qoo10.sg/item/SONY-9-9-E...PEST/664971381
Hmm. $269 - 30 (30 off 300 coupon). But export set from s.korea it seems, and no ratings on the listing yet. hmmmm.
VaIkyrie is online now   Reply With Quote
Old 09-09-2019, 09:01 PM   #906
DigDub's Avatar
Oct new stock then come.
DigDub is online now   Reply With Quote
Old 09-09-2019, 09:09 PM   #907
Woah...that’s very long
Heard in US out of stock also
Old 09-09-2019, 09:11 PM   #908
Woah now become 239. Think can use $30 discount somemore means $209?!
Old 09-09-2019, 09:20 PM   #909
No, if you select wf-1000xm3 it would be $269. Use coupon to become $239.
Old 09-09-2019, 10:48 PM   #910
Still a pretty good deal eh
Old 09-09-2019, 11:33 PM   #911
Had the same issue and sold it off before they pushed out the firmware update. My friend updated his and solved his battery issue.
ksksksks is online now   Reply With Quote
Old 09-09-2019, 11:34 PM   #912
Yes qoo10. 26x
You bought from qoo10?
Old 09-09-2019, 11:35 PM   #913
So you're saying they fixed the battery issue?
Sent from Google PIXEL 3 XL using GAGT
chanbri is online now   Reply With Quote
Old 10-09-2019, 01:05 AM   #914
Yes fixed.
Wondering if anyone tried comply truegrip with these?
Old 10-09-2019, 09:04 AM   #915
Good price leh...
Yes qoo10. 26x
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
