HWZ Forums
Login Register FAQ Mark Forums Read
Neutral or no neutral for light switches
Reply
LinkBack Thread Tools
Old 27-06-2020, 08:25 PM   #1
lifeinmono's Avatar
hi everyone,
i'm planning to replace my current light switches with those wireless ones. But not sure if all come with neutral or no neutral.
went online and found some has neutral and some it doesn't.
I stay in a 7-year old HDB flat, and wondering if it come with neutral.
can anyone kindly advise. thx
lifeinmono is offline   Reply With Quote
Old 28-06-2020, 01:54 PM   #2
RyanJosie's Avatar
hi everyone,
Unfortunately chances are the HDB flat wiring does not support neutral wire switches.
RyanJosie is online now   Reply With Quote
Old 28-06-2020, 03:43 PM   #3
lifeinmono's Avatar
Thanks for the input.
What does neutral do actually. I also found switches without neutral.
Can I use for my flat?
Sent from Binary World using GAGT
Old 29-06-2020, 01:28 PM   #4
hi everyone,
Usually house wiring is without neutral wire. Those wireless switch need no neutral wire usually need you to install a capacitor across light or etc. This effectively complete the loop and get some supply for the wireless logic to work.
Caution for using capacitor method. If you happen to have open circuit at neutral wire. You other lighting or load may carries live potential. So becareful.
cscs3 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
