Blackboxer
- Mar 23, 2009
I have my Asus RT-AC68U connect to the Optic fiber modem in the living room but the wireless signal is not strong enough to reach my bedroom, so I decided to connect the Asus router to a TP-Link Powerline Adapter TL-PA4010P in the living room and in the room I have a TL-WPA281.
I have set both the Asus RT-AC68U and the TL-WPA281 with the same SSID and password so the my mobile devices can switch around.
The problem now is my mobile devices having problem switching between the 2 routes. I can see my mobile phone keep connecting to the weaker WIFI then disconnected and run on data plan then connect to the stronger WIFI and disconnected again and run on data plan and connect to the weaker WIFI again non stop when I am in the living room.
What have I possibly done wrong? Or what else should I do to stabilize the connection?
