HWZ Forums
Login Register FAQ Mark Forums Read
Battery Life Discussion [iPhone 11/ 11 Pro/ 11 Pro Max]
Like Tree4Likes
Reply
LinkBack Thread Tools
Old 29-09-2019, 12:53 AM   #61
2 days and only 5H48M of screen time. So your phone mostly on standby. Still, that’s good to last 2 days. Is that 2 full days?
chanbri is offline   Reply With Quote
Old 29-09-2019, 01:45 AM   #62
Loving the battery life on my pro.
I upgraded from iPhone 6, I had to charge at least twice a day from 10am to 9pm daily.
With the pro, it's still at more than 30% battery after midnight without charging.
__________________
Ish ready to die jialat jialat
Carnage is offline   Reply With Quote
Old 29-09-2019, 07:43 AM   #63
Here’s mine after 21.5 hours of usage. From 10am yesterday to 7:30am today. Well from 12:30am to 07:30am was on standby as I was sleeping. Basically 14.5 hours usage and 7 hours standby. Still have 18% left. Screen on time 09H44M. I’m very impressed with the battery life.
Old 29-09-2019, 08:54 AM   #64
Wow this is really impressive considering your screen on time and your high use of YT, fb and IG, these are the battery guzzliers. Sigh I was so fixed on getting the 11 non pro. The battery is really swaying me to the pro max lol
shunz81 is offline   Reply With Quote
Old 29-09-2019, 10:36 AM   #65
plsbanthem's Avatar
Is it okay to charge the pro at any percentage?
plsbanthem is offline   Reply With Quote
Old 29-09-2019, 11:28 AM   #66
I’m wondering too. My previous iPhone X I charge as and when it drops to 90 or below 80, maintain it constantly at 100 or near 100. Not sure if this method apply to iPhone 11 pro and max. I read this new iPhone just maintain 40-80 can prolong battery life.
tpmmark is offline   Reply With Quote
Old 29-09-2019, 11:39 AM   #67
Im not very sure about iPhone 11 series, but I believe you can check with Apple Support. For iPhone X, the Apple Support told me their batteries are designed to be charged at any time. No need to time.
Akela1673 is offline   Reply With Quote
Old 29-09-2019, 11:58 AM   #68
plsbanthem's Avatar
Which means the same should be for the new lines of phones.
Otherwise it will be a step down.
Old 29-09-2019, 02:11 PM   #69
*adiBOY's Avatar
Not to forget he used chrome extensively which used the most battery consumption.
__________________
人活着就不应该有遗憾。
*adiBOY is offline   Reply With Quote
Old 29-09-2019, 02:12 PM   #70
*adiBOY's Avatar
The battery now can be charged at any time throughout the day. However, try not to let the battery goes below 20% constantly as it will hurt the battery more.
__________________
人活着就不应该有遗憾。
Old 29-09-2019, 04:06 PM   #71
deathst's Avatar
Use the device as you feel like it is most comfortable to you. Don't let the device control you instead. Just don't do anything harmful like completely draining the battery dry.
Technology was made to aid you not you aiding they technology.
__________________
-A Samsung Connections Member-
iPhone 11 Pro Max
Apple Watch Series 4
deathst is offline   Reply With Quote
Old 29-09-2019, 05:24 PM   #72
metamofia89's Avatar
Can charge at any percentage. Just don’t let the battery go into the red zone often, i.e. 20% and below.
metamofia89 is offline   Reply With Quote
Old 29-09-2019, 05:44 PM   #73
Good point. Thanks, think the high cost of the devices in turn made us to be more careful of it. To the extend of “sayang “ it. 😀
Old 01-10-2019, 12:58 PM   #74
RocketBunny's Avatar
Love the battery life.. full day + no issue.
SOT around 9h
best is go to sleep 100%, wake up with 100%.
RocketBunny is offline   Reply With Quote
Old 01-10-2019, 06:41 PM   #75
fade_white's Avatar
Reminds me of this
fade_white is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
