HWZ Forums
Login Register FAQ Mark Forums Read
Laptop dropped & body dented - How difficult is it transfer to another body?
Reply
LinkBack Thread Tools
Old 10-06-2019, 11:50 PM   #16
It might not be 50 for your particular model, I just said mine was 50. If you're lucky you can snap this one up with keyboard intact. https://www.ebay.com/itm/HP-Envy-X36...ty!97008!US!-1
Mine is actually the exact same type except silver (Intel model), not dark grey (AMD Ryzen model) like this 1, otherwise I would have bought it already The Intel model using this body / keyboard all used ones have dents, scrapes, earphone jack broken, etc Only 1 which looks quite good condition but missing a couple keys, that's why wondering if possible to transfer those keys from my existing keyboard over.
CCCustom is online now   Reply With Quote
Old 11-06-2019, 06:23 PM   #17
The Intel one that is the same style with the sharp corners and is silver isn't x360.
wtfh4x is online now   Reply With Quote
Old 11-06-2019, 07:38 PM   #18
Um ... it is, AMD is BQ series, Intel is BP series. Also x360.
Old 11-06-2019, 09:14 PM   #19
My bad, I've never seen that model before. I guess you can buy the brown one if they are the same size, might look a bit weird but you can put a skin on the lid.
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
