HWZ Forums
Login Register FAQ Mark Forums Read
Laptop dropped & body dented - How difficult is it transfer to another body?
Reply
LinkBack Thread Tools
Old 01-06-2019, 04:55 PM   #1
As per topic.
The body is dented such that the charging port area is protruding in a V shape so canít insert the charger completely. The charging port is also damaged but it is a separate module connected by a cable to the motherboard so just need to replace that module, costs like US$10 or so. The laptop itself works running on the battery ... well, whatever charge is still left in the battery anyway.
There are spare part body, i.e. the whole palmrest assembly, available in the market. How difficult is it to transfer everything, i.e. motherboard and all, from the existing body over to a replacement body/palmrest?
CCCustom is offline   Reply With Quote
Old 01-06-2019, 05:22 PM   #2
Depends what laptop it is. If it's an Ultrabook, usually quite easy cos all the components are soldered on the motherboard and the whole chassis is basically three pieces.
wtfh4x is offline   Reply With Quote
Old 01-06-2019, 06:54 PM   #3
Itís a HP Envy x360 ... the type with both M.2 and 2.5Ē hard drive combo.
The palmrest has the holes for the USB / HDMI / power ports at the sides, so this is the main body. Spare part bare palmrest itself without the keys and trackpad can be bought quite cheap actually, so the only thing is how difficult it would be to transfer everything over. The screen I think the most important thing is how to tuck the wifi wires and the screen & touch cables inside the hinge.
Old 01-06-2019, 07:09 PM   #4
If it's anything like my Spectre then the hinges are with the LCD and it's just four screws to detach the entire LCD with the wires inside the hinges. The worst part will be moving the keyboard. It's 50+ screws.
Old 01-06-2019, 07:21 PM   #5
WTF
Old 01-06-2019, 08:11 PM   #6
Moderator
Intrinion's Avatar
Not really hard.
One thing you probably can do / have to do would be to take the opportunity and reapply thermal paste
WTF
__________________
Unsure of what to get? Need help with Notebook issues? Join in the discussions at Notebook Clinic!
Keep up with the latest in mobile technology with Residential Phone Gurus over at Mobile Communication Technology!
Need Assistance? Fret not! Feel free to contact me via PM for Forum Related Issues or any Other Issues that may require immediate assistance and I will get back to you as soon as I can.
Intrinion is offline   Reply With Quote
Old 01-06-2019, 08:13 PM   #7
Moderator
Intrinion's Avatar
I would recommend looking up a guide, ifixit if available or HP’s support guide who often have service manuals available
Get a nice tool kit as well - Xiaomi has a great driver set that was in collaboration with Wiha - a German tools company.
__________________
Old 01-06-2019, 08:29 PM   #8
WTF
I mean they can do what Apple do and make it 50+ rivets instead, which is much more fun. At the end of the day that's the price you pay for very thin laptops.
Old 01-06-2019, 11:15 PM   #9
Was your a spectre x360? I dented my case from a drop and was looking to make a replacement.
cloud0 is offline   Reply With Quote
Old 02-06-2019, 11:11 AM   #10
Yup. 10char
Old 02-06-2019, 11:25 AM   #11
Yup. 10char
could you share where did you purchase the replacement chasis from? any link to guides on replacing the chasis?
Old 02-06-2019, 05:54 PM   #12
I didn't buy the chassis, I had to replace a keyboard, which is pretty much the same work except moving the LCD over.
You can try eBay and hopefully get one with a keyboard still in it.
Look for the hp service manual online for your model, it will tell you everything.
Old 02-06-2019, 11:05 PM   #13
Thanks man
Old 09-06-2019, 01:16 AM   #14
Okay this is may be 1 of those unusual questions ...
The best condition palmrest/body for my model that I can find at a reasonable price with a keyboard attached, has a couple missing keys. If I transfer the laptop's existing keyboard over, it means I am going to screw and unscrew 100 screws just for the keyboard alone, since y'all saying it's 50 in 1 laptop
Is there any way to safely remove the keys from the existing keyboard that are missing from the replacement palmrest/body, and transfer just those keys over? Is there any guide to do this safely without damaging it so I won't end up with 2 damaged keyboards?
Old 10-06-2019, 10:03 PM   #15
It might not be 50 for your particular model, I just said mine was 50. If you're lucky you can snap this one up with keyboard intact. https://www.ebay.com/itm/HP-Envy-X36...ty!97008!US!-1
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
