HWZ Forums
Login Register FAQ Mark Forums Read
[gpgt] Water Cooling Project: Play water kym💦
Like Tree57Likes
Reply
LinkBack Thread Tools
Old 11-07-2018, 04:39 PM   #556
evq
evq's Avatar
can try overclock a bit lah
don't try to break any overclocking records lah
I do sometimes considering water cooling, not becos i want to OC, just want to learn something new. Maybe my next rig, then i seek ur advice.
evq is offline   Reply With Quote
Old 11-07-2018, 04:40 PM   #557
5star_pundit's Avatar
i can help
5star_pundit is offline   Reply With Quote
Old 11-07-2018, 04:49 PM   #558
Let me know B4 you order any fittings cos there are too many and it is very confusing
As a first timer , decide on which type of petg tube and the size to get first
For fittings, the size of the thread is also indicated in inches.
The thread is indicated with a G in front.
The most popular thread size is G1 / 4 ".
then consider Example:
If you order a 1/2 " ID tubing , then you will have to get a fittings with an inner diameter of 1/2" (13 millimeters).
The three most popular tubes ID are:
1) 1/2 "(13mm inner diameter)
2) 3/8 "(10mm inner diameter)
3) 5/16 "(8mm inner diameter)
Example nos.2
if you order 1/2 "(13mm ID) hose, you must order 1/2" (13mm OD) fittings!
likewise order 3/8 "(10mm ID) hose, order 3/8" (10mm OD) fittings!
evq likes this.
Old 11-07-2018, 06:17 PM   #559
Double ssd very impractical and waste money..
Got plans to get a proper monitor instead of using a TV monitor?
just make full use of it since the motherboard support M.2 ssd
Old 13-07-2018, 09:49 AM   #560
when u don't want ur old pc, remember me hor
you don't say earlier
throw away liao
Old 15-07-2018, 12:15 AM   #561
tee tiang ai hoot gaming computer
Old 17-07-2018, 09:01 AM   #562
i siao computer one
Old 17-07-2018, 11:55 AM   #563
anyone wanna to upgrade your existing PC from air-cooled to water cooling ?
Old 20-02-2019, 09:46 PM   #564
too much RGB liao
giddy liao
taste the rainbooooooooow
Old 20-02-2019, 09:52 PM   #565
will get dusty for open air casing
my old 1 and half yr old rig to use for pcw in edmw
6700k delidded
gtx 1080
960 pro 1tb
nzxt hale92 1000watt
Old 21-02-2019, 08:43 AM   #566
zjllee's Avatar
Can you post some benchmarks of your PC? Should be interesting.
zjllee is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
