HWZ Forums
Login Register FAQ Mark Forums Read
Need advice to work on wireless measurement device!!
Like Tree1Likes
  • 1 Post By davidktw
Reply
LinkBack Thread Tools
Old 19-05-2015, 07:22 PM   #1
I don't really exactly understand fully use of ultrasonic sensor or infrared sensor.
But what I am looking at the type of sensor I need to measure a distance between a receiver and transmitter to work with ardiuno project. I need advice which shields I can look up to that I can work on it. Thanks
696E20727569 is offline   Reply With Quote
Old 20-05-2015, 03:37 AM   #2
davidktw's Avatar
infra sensor is just a piece of device that reads the infra red spectrum of light. Normally it is quite expensive if you want to consider reading beyond a single point of light like this - http://www.flir.com/flirone/explore.cfm
Ultrasonic sensor is a high frequency sound waves receiver, but actually it's more like you are looking for a transducer, one which can transmit and then receive. Measure the delay and you can deduce the distance travelled by the sound waves.
http://www.arduino.cc/en/Tutorial/Pi...trasoundSensor
696E20727569 likes this.
davidktw is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are On
