2.5 Gbps wired home network
jasonho
nice!!
I also have ordered my 2.5G switch (TL-SH1005) from Taobao.
Did you need to install any driver for the openwrt router to detect the ugreen adapter?
I am running OP under ESXI. I installed the USB (Realtek) driver under ESXI, and created a VMNetwork interface before adding it into the OP virtual machine. If you are having similar setup, do remember to choose VMXNet 3 for adapter type.
For ESXI USB Network drivers, u can find them here https://flings.vmware.com/usb-network-native-driver-for-esxi#requirements
If you are running native OP, just check if the OP image contains those USB 2.5G (Realtek) drivers.
Elijahonli
Sorry what is OP ?
Elijahonli
Sorry my bad habit of using abbv.
OP - Openwrt
can share what are the other things you have installed on your custom router?
I ordered the same router too, waiting for it to arrive :D
jasonho
Beside ESXI 6.7 and OpenWrt (China version), I have pfense image but didnt try out yet. Also my Win VM image.
It depends on your configuration of your box.
