moolala
- Mar 2, 2020
Real rates are already at 0% signalling a recession.
is there a inverted yield curve?
Last night's fall was not surprising since we had established a lack of professional participation to buy while flagging the possbility of new supply when virus spread hits the headlines. Both the bulls and bears are slugging it out here with no clear winners. Both forces are strong as marked by the increased volume and wide price gyrations. However wide the price swings, I note that we have been having a series of inside days on high volume. The jury is yet out.There has been congestion around the 3000 level in the SP futures, a level that was resistance turned support on break above. However, given the bearish change of behaviour, I am inclined to think that this level would still be tested again and potentially break if the virus spread becomes more widespread. 10y UST yields are breaking lower and I would take the lead from this to maintain shorts in the equity markets.
There were a few reports last night highlighting that investors are seeking safe haven in Real estate. And we see this quite clearly in the Singapore Reit space. I would caution against getting carried away in this play as it is a very crowded trade. A rate cut does not benefit DPU directly as most Reits would have locked their interest rate liabilities into fix rate loans. In any case, the mark to market losses on these fixed rate swaps would rise as interest rate falls - the interest rate expense bill would not decrease unless the Reit has taken up a new loan for a new project - yes new projects. Refinancing of existing loans mean that the REIT would have to pay up on the mark to market losses on their fixed interest rate swaps and reducing their DPU. For investors piling into REITs, it would be a call that the crisis would not last long enough to impact underlying REIT tenants. a prolonged slowdown in business or recession may see REIT catch up or exceed the broader market underperformance as they would have fallen from a higher perch. That said, the prospect of more rate cuts may well see more and more funds seeking haven into REITS in the near term and it would be sometime before the Reit space turns down on recessionary fears.
If the market continues to sell off, some of these stocks could slide further too, albeit less so?
If you don’t mind sharing, are there any particular sectors you are examining?
thing is the fed is being proactive here hence the unnatural drop in real interest rates. in fact if you take inflation at 1.5% and the fed funds at 1-1.25%, real interest rate is already -0.25% to -0.5%. but I don't think real interest rates can be used to signal a recession since part of the cause of this is active intervention by the fed.
perhaps the earlier yield curve inversion in september 2019? If going by the stock market as a 6month leading indicator and that it takes 1-2 years for recession to occur after yield curve inversion, we are looking earliest in September 2020.
Posted from PCWX using Redmi K20 Pro
I do not think the Fed is being proactive. I think they have made a series of policy blunders. And the recent cut is another blunder that attempts to patch up earlier blunders. Rate cuts were not warranted at all last year... in fact they had an opportunity to withdraw liquidity and normalise rates but they did not. Now they are boxed into a corner.
Given the excess liquidity in the system, it is doubtful if inversion may be a reliable predictor of recession as in the past. Demand was artificially propped up by central bank actions.
maybe i should say they are too proactive because they are trying to get ahead of the curve.
I'm pretty goddamn sure that the fed knows it is committing the policy blunder because back in 2011, jerome powell was actually against QE, saying that it distorts the excessive risk that the market is taking.
If the fed had not made the rate cut, it could be argued that the yield curve inversion will happen sooner since the fed funds rate affects the 2 year yield significantly and cutting fed funds rate could lower 2 year yield to prevent a yield curve inversion from happening.
Will limster unlock his warchest now that STI ETF is under $2.99?
In a bear market, all sectors would trade down. I adopt a bottoms up approach and would only look at individual stocks to bottom pick or for certain stocks that have been deeply oversold and which measures cheap by most valuation methods. I would enter positions when I see accumulation of these stocks based on Wcykoff's works. That way, I have fundamentals and potential institution backing my buy calls.
In any case, the path of least resistance is to the downside. So shorting rather than buying would be the order of the day.
Waited long time since 2016! But starting small first because its end of the trading week, prices may be distorted by shortists needing to close their shorts.
Will continue to average down next week.![]()
Swee. You walk the talk.
During the last GFC, I also started at around $2.97 (last time don't have 3 decimal places) and followed the falling knife all the way to $1.4x, though personally I hope it doesn't fall that far. I hope its more like 2016!![]()
https://www.reddit.com/r/wallstreetbets/comments/fe5s7e/the_fed_repos_are_an_attempt_to_prop_up_the/
if this guy is right, major major crash incoming
