30s-50s chitchat club - Part 66
Autumn.
It's very effective. I typically play thief mage and fireball is b&b.
Quite a lot of ppl run very tight numbers so just burn down some buildings and they become overpopulation already.
if numbers crunch correct, usually there is only 3-5 provinces in a full kingdom keep sending man to alliance to make thieves. in mid of war, all attackers, should only have 75% population cap. that is why timing v impt must send out within 1 min of troops arrival to minimise loss of population
RyanJosie
I don't do it often too... Most of the time is robo vacuum... Then mop occasionally..
But i think I do a poor job at mopping cosz floor will feel abit sticky :(
I got do 2 rounds though.. Once with detergent... 2nd with clear water
Any good robo vacuum to recommend ?
RyanJosie
I agreed but which gen is not double edge sword haha
no Way housing cost can match income increase cos you always have earlier gen who made it to fry up the housing price
So despite absd should go all in ?
harbinger255
there is no utopia ness in it
it is war mongering
Think I gave up after the 2nd season... Went back to take a look after a few years... Cant recognize it anymore..... :o
Think still got another one quite popular one.... Think was called archmage or something....? :s13:
aceminer
Jin ho chio. My coy desperate until doubled the referral fee if we can do a successful referral
aceminer
I am looking at one to do some background vacuuming , but I will still do the usual vaccuming and steaming.
But my kiddo stuffs strewn across the area .. zzz
I dunno man I don’t use any
TonyDelPiero
I am using ECOVACs 950
Pro : can map the flooring.
con : your wifi in the house must be good .. else connection cut off they will get lost
so mine must send it to the weakest Wi-Fi area and move downward to the strong Wi-Fi area
Satki to the max! Review so deep! But WiFi problem is easily fix-able.
dry_county
bc v6 louji. i sold mine away after 2 yrs. in that sense, i only loss 250 and i still get a new Vac for $550
I'm still holding on to it. my helper now use it to vacuum mattresses, sofa etc.
