4-pin and 8-pin on motherboard
evq
My x99 sabertooth has both 4 and 8 pin. Must I plug both into my psu or either one. The manual not clear.
Currently I only connected the 8-pin and the 24-pin. I am experiencing random reboot. Sometimes during light gaming or just idling.
And during the reboot my pc will cycle a few times before post. Just on then off then On again. Whether is it becos I nvr connect that extra 4-pin or my gpu got intermittent problem.
I not running sli.
Pls help. Thank you
dreamer_toons
I connect to both 4 and 8 pins and all is fine. According to the manual, the system may not boot properly if either 1 is not connected.
evq
Oh, I didnt see that part of the manual, mind sharing which page?
anyway, i connected both 4 & 8-pin last nite. Today will monitor.
Thanks for the reply
evq
Ok, i read that portion before.
'DO NOT forget to connect the 4-pin/8-pin EATX12V power plug. Otherwise, the system will not boot.'
I understood it by either one of them. hahah.
It shld use "4-pin and 8-pin".
I googled, most ppl say it is ok to leave the 4-pin unless OC. Anyway, I will have both of them plugged in.
Hopefully this solve my system reboot issue.
Thanks again
dreamer_toons
Thanks again
Yes, I was confused by it initially too; especially the wording 4-pin/8-pin.
I decided to connect it anyway during the setup and the system has been running fine.
Maybe other who are more experienced may comment on this 4/8 pins connector.
ondooy
8 pin would suffice, the other 4 pin is for extra power...
8+4 is when you have all pcie slots populated...
kandinsky
Thanks again
From reading around the net, opinion is divided. Some people feel better plugging both, some ppl prefer either or.
One comment I read on the asus forum:
The EATX12V_1 and EATX12V_2 are alternative connections.
Since your board demands a minimum of 450W, and not all of those small PSUs have a 8-pin EATX12V connector, but perhaps only a 4-pin connector, the board has been supplied with an own 4-pin socket for those PSUs.
But since your PSU has an 8-pin EATX12V connetector, that one - and only that one - should be used.
I might add that connecting also the 4-pin connector would not cause any harm with modern PSUs which are usually using a single rail 12V. I would personally only connect the 8-pin connector though.
(In most cases there is only an 8-pin EATX12V socket on the board, which often has 4 pins covered by a plastic cap to guide a 4-pin connector to be connected to the correct pins in the socket.
Also that has always caused confusion about this with the cap).
So, you are correct in only connecting the 8-pin EATX12V connector to the board.
https://vip.asus.com/forum/view.asp...e&id=20120303161417837&page=1&SLanguage=en-us
evq
ok, hope my reboot problem will be solved.
I only has a GTX970, 2x ssd, and corsair H110i GTX. my other 2x hdd r not connected as i am still troubleshooting.
Yeah, I have been reading ppl saying this as well.
Wow, this board eats 450W? or is it with all PCIe slots used?
Does ur SLi plus board has both the 4 & 8 pins?
evq
just to update,
after connecting both the 4-pin & 8-pin cable to my mobo, been running since 27th Oct, no reboot issue.
kimsix
just to update,
I also connect both the 4 & 8 pin cable and found it more stable with overclock at 4.5ghz. Initially I connected only 8 pin and it still works but I get random overclock error.
evq
I didnt OC. and I only have my 2x ssd, H110i, and a gtx970 setup. These did not connect directly to my 850W psu.
Only 1x 120mm & 1x 200mm fan connected to the mobo.
Good to hear that, enjoy your rig.
Thanks. Yeah, enjoying it after so many problem surfaced when I first got it setup. :eek:
