8-hour rotating shift ops role for $6-6.5k kym?
JonWeak
Wah notch bad leh. Just do for the money lah
brownkai
As per topic.
Anyone with rotating shift experience? It really drains your health?
Where to apply... 8 hrs I wan... Just need to work almost daily... Cos 3 shift rotating but time very fast end one for 8 hrs shift
CkJie05
Almost a decade back, i did 14 hours shift as a principal and SI.
sibei tough on health. Even the Principals uncle told me not to stay on this kind of work for too long.
good engineering learning experience though
tank_t
Do simi ops?? The $$ not bad. I like ops job cos once off shift can relax liao. No need to follow up anything.
sickoflife
Want to do night shift, must do all the night shift all the way.
Alternate between day n night is the killer.
Even perm night shift also xiong. Confirm got some day time where u can’t sleep or want to play.
claypot_king
Any shift more than 12hours can report liaoh..
Spirax
Yes, difficult also, off day, sleep pattern also change, most young pretty lady become haggard after 2yrs
Tokieda
night shift is bad..try to stay away. if you can
Philipkee
As per topic.
I just tell you. It is NEVER 8 hour rotating shift.
Cos if you rotate, you need to handover. So you have to stay back or come early. If there is over lapping time, its means one shift will be longer - usually night shift.
Example
12 hr shift 8-8. You can start at 8am but by the time you handover, you leave only at 830 pm. If you come earlier to check stuff, you are working from 0730am to 8pm.
Same if it's 8 hr shift.
Plus how do they schedule the timing? Even if its so good no need to hand over.
7-3, 3-11, 11-7
You will be going to work and off work at odd hours and there is a chance that one day you are 3-11, next day you are 7-3. Little rest.
Maybe it's not 7-3. But what's the option? 6-2? You could to work damn early. 8-4? Means afternoon shift you go off at midnight (transportation costs).
So shift is taxing. Good allowance. Can have off on off peak periods. But it's still taxing.
ohsinga
Last time moi worked rotating shift in ops at a bank, really bad, esp diffc to sleep when switching
Many of us request for either one shift but was rejected, bcos mgmt want us to learn every shift job tasks
