[Advice] many years since i upgrade PC liao...what to upgrade and where to bai? arigatou!
XusioN
budget $900 to upgrade motherboard, CPU, RAM and gfx card...possible to get DDR4 type motherboard with this budget?
any recommendation? and also do people now still buy from SLS? if there is any online shop to buy from, will it be amazon? i see amazon a lot of things nv ship to sg especially hardware...and also no warranty from amazon right (local).
so quite curious whats the upgrade process now...i haven't upgraded my system for 4 years...my PSU is 450 watts...i want to keep the system to 450 watts...save electric bill haha
XusioN
thanks for replying
current specs : AMD phenom 2 x2 550 BE
4GB DDR2 ram (2x2gb)
5750 gfx card
PSU 450 watts andyson
120GB SSD
1TB HDD
thinking of replacing CPU, mobo, RAM and gfx card while using the same PSU
use it to play simple games...and run some system stuffs...ideally 16GB ram in DDR4...arigatou
Difficult leh unless get quite entry level parts
How about you list down your current parts and your pc's usage?
Sent from a mere cat using GAGT
monikernemo
Simple games as in FB Flash games uh? Or 3D games?
Was thinking that perhaps you get a basic Skylake i3 but run on integrated graphics? Hmm 900 can be difficult if you want ddr4+ skylake+discrete+new gpu
XusioN
oh...games like dota 2...or some steam games like F1
if 1k possible to get? my budget for gfx card is 200 bucks...i dont play intense games...CPU and RAM more impt for me haha...
Jian19
i5-6500 + Msi b150m bazooka ~ $444
Kingston 8gb ddr4 x 2 ~ $168
Palit gtx950 stormx ~ $270 (Lazada)
Fsp aurum s 500w ~ $89
CM n200 ~ $61
$1032 buy and did @ pctheme ask for discount.
royfrosty
Your psu is not worth to keep for the new rig. So yes. Change the whole pc instead.
monikernemo
What's your casing though? Or you need new casing also
But if casing to stay put, here are my inputs:
From amazon:
Crucial Basic DDR4 ram 2*8GB @ 89USD
You can get the ballistix version if you find the lack of heat spreaders gao wei
GTX 950 EVGA @ 160USD
Local prices for GTX 950 around SGD 270. This is alot cheaper at ~235. While I note that Lazada has a Gtx 950 selling for 239, you can ship this together with ram for free shipping to sg. Also, evga warranty just send to Taiwan, not all the way to US.
Gtx 950 will be sufficient for Dota 2 and F1?
Subtotal for amazon: ~ 361SGD (1 USD ≈ 1.45SGD)
From pct:
CPU + Motherboard: B150 MSI Bazooka + i5 6400 ~ 419
If you have other add in cards, maybe get the Mortar for 20+ dollars upgrade?
PSU: Superflower Leadex Silver 550W ~ 119
PSU better change bah if it is aged.
Can buy from Lazada for higher discounts.
Total: 799
Jian19
If wan to match white black theme can consider Asus gtx950 oc or Msi gtx950 oc
Think is white...price around $270 as well
XusioN
arigatou! will take a look!
CM n200 ~ $61
yeah true...PSU old liao...might cause problems
using lian li...will take a look :D thankew
From amazon:
From pct:
Total: 799
no colour preference...just a simple rig lol
arigatou for the help!
find fortran, lazada not much discount lately :vijayadmin:
