Advice pls: Lousy WAN-LAN throughput on Netgear X6 R8000
fatthumb
Hi Networking Gurus,
Need some advice. Last Comex I bought Netgear R8000 to complement my M1 1Gbps fibre plan. Connected the router by Cat 6 cable to my PC and run speedtest.net.
Results were shocking to say, below is using my old Asus N56U
Below is using Netgear R8000
You may notice that I took the test on different time, but rest assured it will be same results.
I have updated R8000 firmware to latest official build from website, currently I'm now running latest Kong build DD-WRT firmware. Both official and DD-WRT firmwares gave me same results (~500 Mbps down/upload) :(:(:(
My Asus N56U is running on latest Padavan firmware, easily get ~900 Mbps down/upload.
Both routers support gigabit LAN but no matter what I do to the bloody Netgear I can't achieve it.
Did I get a lemon router with lemon gigabit ports? Any gurus can enlighten? :o
jtjt00
Are you using the same port from ONT and the same set of cables for both routers?
Ah-Pin-Kor
Does kong's build have ctf enabled now?
I'm surprised you can get 500Mbps using dd-wrt.
fatthumb
probably you have got a lemon then... tried asking netgear for help?
Not yet, I always tried forum first. To be honest most of the time those online support quite useless, probably they asked me to bring it to the service centre and I'll be routerless for few weeks :s8:
What is ctf bro? I'm not that familiar with dd-wrt just flash it to see whether any diff in LAN throughput.
albertlee
TS, have you try speedtest using the stock firmware? Most 3rd party firmware are unable to implement NAT (CTF) hardware acceleration as the code are not GPL.
fatthumb
Yup I did both stock and ddwrt firmware, doesn't make any difference :s22:
However I liked ddwrt since it give me more flexibility over the wireless settings. I can get >250 Mbps down/up with my Note 3 over one of the AC 5 Ghz band.
albertlee
Check if both Upstream/Downstream QoS is enabled, if yes then disable both.
If all else failed then probably high-time to give Netgear a call.
fatthumb
QoS disabled already, submitted a ticket to netgear support :(
fatthumb
Ok I got to tell you guys this, I have been tinkering with the setup until now and somehow I can get >900 Mbps over the R8000.
The setup is:
TP >>> Huawei ONT >>> Asus N56U (main router performing as DHCP server & NAT, wireless disabled)
Asus N56U >>> connected through LAN 1 port on both routers >>> Netgear X6 R8000 (secondary router, wireless enabled)
I ran another Cat 6 cable from LAN 2 port of R8000 with this setup and Viola speedtest showing >900Mbps download upload :D
Some details (in case any other bros encounter same problem):
N56U running Padavan 3.4.3.9-095, router IP 192.168.1.1, DHCP from 192.168.1.3 onwards
R8000 running Kong build DD-WRT v3.0-r27775M (09/07/15), router IP 192.168.1.2, DHCP forwarder with DHCP server to Asus IP. In "Advanced routing", set operating mode as "router" and dynamic routing interface "both WAN and LAN".
But still puzzled why I can't get 1Gbps throughput directly...
jtjt00
TS, you connect LAN port 1 of Asus router to LAN port 1 of R8000? Should connect to WAN port of R8000?
