AIO liquid cooler and air cooler
Xteron
Hi all, shortlisted a few cpu coolers but can't decide on which to get. Need some advice...
Liquid
1) Corsair H60
2) Corsair H100i (but overbudget)
2) Deepcool Maelstrom 120k
3) Deepcool Maelstrom 240 (no1 choice for now)
Air
1) Xigmatek dark knight
Will be doing some light oc with stock voltage on i5 6600k.
My concern with liquid coolers are durability, coolant leakage, etc... experienced bro pls advise thanks!
Toby88
Personally I think that since you are already using Hyper 212, stick with it? Perhaps change out the fans to static pressure optimised ones?
Other than that, an 'upgrade' would be a 240 rad due to larger surface area hence better heat dissapation. Anyway, any reasons not to consider many other brands?
Clearance is usually tagged to casing and ram height. For rads, its always best to have cases that have big offset spacing.
Xteron
thanks for ur advice bro.. yeah i'm more towards liquid coolers with budget arnd $100 so with 240 rad, i think deepcool maelstrom240 is my no1 choice for now.. but not sure of the brand's reliability, noise, performance, etc.. Corsair H100 too ex..
I'm open to suggestions from other brands as well.
zystttt
Stick with 212 or upgrade to Xigmatek Dark Knight or Noctua NH D-15. But since you mention mATX then its prolly out of the question. For liquid I can say Deepcool works but they are not the best imo. I've read reviews on V8 GTS in the past and they say for the price paid its not exactly worth the money given the performance, unless you are after the aesthetics. Long story short, advice 240mm rad or noctua for air.
edit: to give a different view from Entry Level PC, my temps dropped 12 degree at load after changing from air to aio.
Xteron
hmm.. for 240rad, which cooler do u recommend??
what abt corsair h60 120rad ?
royfrosty
Heres my take on air or liquid cooling. Theres both good and bad on either sides. Assuming that you have chassis clearance for either type of coolers.
Air Cooler Advantages
- Easier to install
- Cannot spoil unless inflicting physically damage to it or badly oxidised for bare copper.
- Basically lesser pump noise
Disadvantages
- Some low end air cooler performs the same as intel stock cooling performances
- Dumps heat in within the chassis
- Some higher end ones cost almost the same as a mid high end Aio cooler, and performs roughly the same performance.
- More things to consider for clearance, such as height of cooler, how broad is it, does it interfere with high rams heatsink etc.
- Most of the time the stock fans provided performs poorly out of the box, needing end users to extra purchase another set of good fans.
Advantages of Water Cooling
- Lesser clearance issues. Just need to find a proper 120mm or 240mm or 140mm or 280mm fan slots. Pumps are generally small and does not interfere with things like Ram heights, chassis issues.
- As most of the time the radiator is straped nearest to the fan mount holes helps to exhaust the heat out from the chassis. Resulting in much more efficient way to dump heat.
- Mid high to high end Aio coolers are found to be more effective to cool cpu down faster than air cooling.
- Aesthetically much more neater and cleaner look.
Disadvantages
- Noise from pumps
- Risk of tibe connectors to give way if over strain of tubings
- Generally more expensive than air cooling.
- buying really cheap ones such as slim 120mm radiators have the same performance or is worse than high end air cooler.
If i were you.... for overclocking and overvolting of cpu, it is best to go for proper watercooling aio. Such as the Corsair H100i GTX. This will be a proper buy for overclocking. Invest on a good one and that will be the only thing you will buy once and for all.
Do not be too worried on tubings being burst or tubes have holes on it.
Generally aio cooler tubings used are one of the hardest to leak or burst when they are using rubberised tubings that are so elastic. The only thing that one has to worry is by not stretching the limit of the tubings can go. Other than that you will be fine for years.
Xteron
thanks for ur detailed reply roy. btw i won't be overvolting in the long run... most likely will be running at default voltage and OC a little. So i was wondering if corsair h60 can do the job.. or more worth it to get the deepcool 240. No doubt H100i gtx is a good cooler but its quite overbudget so im still considering that.
btw, my mb and case : i5 6600k + Asus Maximus VIII gene and Thermaltake core v21.
royfrosty
If you overclock it, and when voltages are set to adaptive (default), it will still overvolt. Not unless you fixed the voltages to be constant supply of whatever voltages it is. By doing so, even at the lowest core clock you will still run at the fixed voltages.
More or less, you are still overvolting once overclocked.
Tbh if you buy a H60, you are better of saving the money till you can afford to buy a good cooler.
No point skimping now and buying whatever cooler with your budget. Then at the end of the day, you still have to go for a better cooler.
I think for now the very least you should ne looking at is the deepcool maelstrom 240. Or a single thick radiator such as Corsair H80i and Thermaltake Water Pro 3.0.
naked123
you can get cosair h100i gtx for $155. plus the stock fans are good enough for me so no need spend extra.
royfrosty
$150-$155 already can get the h100i gtx.
Ek predator x240 also a very good cooler. Just for serious water cooling features x240 is a good buy but a little more pricey, but you get everything the best of ek could give.
Xteron
can sic which shop for h100i? :s13: tradepac?
Krabs.
5yrs ago I also thought liquid cooler very cool and all that ...
now I don't consider it anymore , reduce the likelyhood of pump failure and the constant power consumption of 1 more component (about 3watt)
continue air cooling ....
stock voltage light OC , no temperature issue on skylake , don't need worry
the voltage that goes into the core is lower than what the bios or OS software can tell you , tweaktown guy asked the intel israel team that designed skylake
royfrosty
Dont even need to go down to tradepac.
http://www.lazada.sg/corsair-hydro-...rformance-liquid-cpu-cooler-black-678224.html
Lazada convergent is selling at $185. Although it is oos for now. But im sure it will come in again soon.
Give you lah, even you do not have coupon and the worse case scenario you buy using mastercard at 10% off is already at $166.50. With shop back it will be a mere $160?
That is the worse case scenario if you have no coupons to buy.
Note that the best case scenario it went below $160. Only 2 shops in sls will bother to sell at that price or at times lower if you know how to bargain further.
