Alldocube Iplay20/Iplay 20 pro
xtractor
Alldocube Iplay20/Iplay20 pro
Just got mine delivered today
ordered through Banggood
Bubble wrap
normal packing box include with socket:s13::s22:
this is what u pay for and i am okay with it
Charging cable Type C great to have it
in term of size smaller than my current tablet note 10.1 2014
but screen size is the same
Tablet already fixed with screen protector
Preinstalled Playstore,Youtube and Google Map
Sync to my Gmail account and auto copied over whatever that is on my S9 plus from normal Apps and Games
no need to reinstall them back again
No fingerprint sensor
No Face recognition
Only 1 speaker located below near the charging port
Volume max is quite loud tho
xtractor
is there anyway to On the tablet without pressing the power button?
tried tapping on the panel nothing happen
Only way is to press power button physically
also the display icon that is on top of the clock cannot be remove
it just stick on top there tried click on it but it goes to preferences
Fingerprint Magnet:s22::s22:
shown as Iplay 20 but of course it is Iplay 20 pro
running on latest update Android 10
as mention is it on Widevine L3
nothing much u can adjust
xtractor
Comparison video with my current samsung galaxy note 10.1 2014
Which one did you look better?
i dont see any different
left Alldocube Iplay 20 pro
Right Samsung Galaxy Note 10.1 2014
xtractor
lastly with casing :)
bryant_16
Great! How's the performance for you right now?
Any sluggish performance or occasional lags here and there?
xtractor
when i did the test run web browsing side by side with note 7 pro it is a bit slower by 1 or 2 sec
so far i dont encounter any lagging
Geek Bench result
Run twice to get the consistant result
Alldocube Iplay20 pro
Redmi Note 7 pro
bryant_16
Do you have the video of side by side of note and iplay20 web browsing performance?
bryant_16
Ok thanks alot. Still thinking to get. Performance will be important.
Teo Ming Ern
Can use TPG voice and data or play .ts files?
Can use TPG... I tried... also ok with Starhub and Singtel... the China tablets thread - someone tried M1 also... so no issue with the 4G bands in Singapore... note that I tried data only... didn't bother with voice since I won't use it as a phone...
For .ts files, you just need the right software... I like MX Player...
value0230
Can play 1080p on YouTube? Some lower end phones / iPad 1 can only play 720p.
Yeh im using MX player too. But notebook sometimes cant play.ts files with VLC player.
Teo Ming Ern
Absolutely no problem with 1080p YouTube... smooth with no dropped frames... I don't use MX Player cos the included video player seems good... VLC can't play back .ts files? That's weird... those are DVD files right? Maybe need to do a virtual disc mount? You tried?
value0230
Cool. Can do some work with Excel or word. Will hang?
bryant_16
Is there local warranty for this?
I'm deciding between this and the new Amazon Fire HD 8 or 10.
Teo Ming Ern
No local warranty lar... apart from what the seller offers... buy China tablet, don't even think of warranty...
value0230
Excel worked great and very smooth.btw Excel already there on the tablet pre installed
Cool. how long from banggood. Thought lazada will be cheaper and faster. banggood looks like AliExpress (which is known for long delivery)
xtractor
It took 2 week to received.
i bought @ banggood because before that there isnt sale yet @ lazada
but now u can buy at Lazada at cheaper price from Bestgreen
https://www.lazada.sg/products/new-...o42.searchlist.list.3.53ac301aZlyxmS&search=1
but u cannot wait few days and decide later to buy because i see it goes oos so fast.as he only stock up 2 tablet one time.then no choice u need to buy it at banggood
yusoffb01
fire tablets ping amazon too much and lower battery life.
this one is stock android 10
