ASUS RT-AC3200 Dropping Singtel Fibre WAN connection
Lennion
Would like to seek help as titled pls. Just changed from AC87U to AC3200 but had a hardtime setting it up. Can't get it worked initially with the WAN light being red. Tried a few things, including using Manual settings for IPTV etc. Eventually got it working, flashed to 9135 firmware and switched to to profile of Singtel-Others.
Was ok for about 5 hours but just lost WAN connection again. Checked syslog and these was the last few lines:
Nov 8 14:08:40 WAN Connection: Ethernet link down.
Nov 8 14:08:40 DualWAN: skip single wan wan_led_control - WANRED off
Nov 8 14:08:40 stop_nat_rules: apply the redirect_rules!
Just managed to got it back after switching ONT off for 5 mins. Wondering if I should send the set back to service centre for a check. AC87U was much seamless when it comes to setup.
Can any expert advised, pls? I am on Singtel Fibre 500M. Almost wanted to post my AC87U up for sale but think I better hold on it for a while more...:(
renfred89
Update the router firmware to 9135.
Them perform a reset on the router. Let us know if it helps..
Choose iptv singtel-others and it will simplify alot of things..
Lennion
Already updated the firmware and had selected the Singtel-other profile. Just lost WAN again...
Off and On router and the WAN came back again...
Can advise what is the proper way to reset router, pls?
renfred89
Press and hold the reset button until ur power led flashes..
Usually a reset will work. If not ur unit might be spoilt lor..
WWE_Fan
Yea, looks like abnormal behaviour of the router. Resetting should work. Otherwise, could be hardware issue.
Lennion
Thanks renfred79 and WWE_Fan for the help. Had it resolved...
Basically had a lemon... Brought back to Service Centre and they had it replaced. Connected smooth and swift now...! :)
