Australia to reopen border from November
belgarathc
It's crazy, really hope they change to ART instead, doesn't make sense to Q up to 5hrs for a test just to satisfy some bureaucrats..
This SG AU VTL seems poorly organised, at least from AU side.
beano
Indeed, especially during this time where tons of interstate travellers need to also get tested to travel to QLD. Doesn't help the situation at all, hopefully they move towards ART in time to come.
beano
Just flew in SG -> Melb yesterday, and process was smooth all the way through.. just did ART within 24hrs.. another one 6 days later..
tinkerbelle
hi, can i check if you did the ART using your own kit or was it a supervised ART? do you need to show anyone or upload your ART result anywhere? thanks
beano
Which leg are you talking about.
Pre-departure from Aust -> SG, yes supervised. Done at the airport pathology
On arrival in Aust and day 5-7, self test, not supervised.
tinkerbelle
thanks! i was referring to the ART on your arrival in Australia.
figo16
Must ownself bring Art test kit to OZ or can buy over there? What is the brand of the test kit?
beano
There's zero stock in retails here, you can bring your own, Panbio is approved here.
figo16
Pabio ex leh. $96 per kit. I bought Flowflex $24 only and iit is approved in Aussie.
If I arrive in Sydney then go Tasmania on Day 5 does this mean I no need to do self test since Tasmania doesn't require any test?
Maybe should fly to Melbourne instead. No need to do self test in Victoria during day 5-7
beano
The rules keep changing, yea just read that Victoria doesn't require ART even on day 5-7 now.
beano
Also if you intend to go Tassie, better to come to Vic so there's a choice to take the spirit of tasmania cruise over.
dilphinus
For pre-departure test to Australia, from 0100hrs 23 Jan, ART/RAT is accepted. Have to be medically administated.
$38 + $59 (RAT in AUS for pre-departure to SG) + $125 = $222
beano
That's about right..
