FastFixer
- Feb 1, 2015
I see many people asking questions here. For a change, I would like to share useful info with all bros regarding car batteries.
The topic for today is: Car Battery Terminal Head Corrosion
WHY IS MY BATTERY TERMINAL HEAD CORRODED?
WHAT IS THE BLUISH SUBSTANCE?
Battery terminal head corrosion happens when the electrolyte (sulphuric acid) in the battery makes it way out of the battery due to leaks or joints over extended time (years). This is not something uncommon and AFFECTS CAR BATTERIES FROM ALL BRANDS
HOW TO FIX THIS?
Luckily it can be easily fixed (before battery fails). To clean up the substance, spray a baking soda mix (1 part baking soda, 5 parts water) on the terminal head. The copper sulphate will dissolve and you can brush it away with a metal brush. The bluish substance is actually copper sulphate which is formed when sulphuric acid comes in contact with lower grade copper battery terminal rings that are not alloy plated.
For more info about this (and others about car batteries), follow this link:
http://www.fastfix.com.sg/car-battery-general-FAQ/about-car-battery/
HOW TO FIX THIS?
