City Gas pipe installation
harky
Deluxe Member
Hi,
i had lay my gas pipe for a while but due to Malaysia CB, my kitchen cabinet was delay and i spot someone ask this question so i am abit worry
My is old resale, so pipe will run from outside to living thn kitchen.
For what i know there is 2 steps. first install is lay pipe, 2nd install meter and turn on
Now, for what i know is.. when they lay the pipe, they suppose to do pressure test also before i up my kitchen cabinet.
So when there is leak, they can fix the pipe.. cant be after i up my cabinet, test, found leak and tht time i had to cut hole for cabinet ma....
I was there during the installation and i did not see the contractor do any pressure test.
Call citygas, they insist their contractor will do pressure test but they cant provide photo or video to proof.
and say they ask me to pay $$ for them to test, if leak they offset. if nv leak they ask me pay
harky
Deluxe Member
Anyone? ????? Really
nakata97
You got the answer. So what else you need?
nakata97
You just stand near the pipe. See if you can smell anything.
if nothing, then go smell a durian. If still no smell, means you got Covid
if smell got gas, call city gas and Kan them lor
ODACHEK
A Better Tomorrow
We had a similar situation like yours when we received a letter about testing the pressure for leak. Under the amended GAS ACT or something, this responsibility falls on the owner and needs to do a regular test every 3 years.
Hope it helps.
harky
Deluxe Member
huh....... meter havent install le.. how to smell..
they only push and say their contractor do.. but i nv see them do..
if i install my cabinet, later leak, i need to pay them to hack meh?
harky
Deluxe Member
Hope it helps.
new install le.....
