Does anyone actually buy portable air pump for car?
Zze121
on run flat tyres, its noisy
kanna b4 on a re001 was nozzel spoilt cannot pump
TopGun
Deluxe Member
If you want to keep the pump in the car, get those batteryless and run off 12v type.
Batt powered ones are good to keep at home and pump your bicycle, sex doll etc or pump your car tyres at the carpark.
locksleychang
I have one. I use it to pump my car's tyres on the first weekend of every month. Can pump from cold, can't do it if you pump at petrol kiosk. Also, I can do it in the sheltered MSCP instead of under the sun at the petrol kiosk.
Also, the hose at the petrol kiosk is quite dirty. Use my own air pump is cleaner. And yes, can pump other things like balls, bicycle wheels, etc.
IIIUSION
This is good for those carpark lot snatchers. Will need to use quite often. :o
Whispers
got link for the direct connect to ciggie lighter pump?
thanks
ChenHoNam
i pumped 2.5 bars few days ago for all 4 tires.
this morning one of it beeped and beeped.
one of it went down to 2.3 bars.
happened twice already.
something wrong ?
sunsetbay
Moderator
Moderator
Xiaomi air pump 1s not bad~ got a small LED light which is pretty useful in the dark~ the pump is pretty noisy same as others motorized pump~ :s22:
Spirax
All gas stations have air pumps and u will always need gas before u need air, yes? :s11:
Or am I missing something.
Do not used gas station pump, sometime the internal pressure needle and valve are spoil which can cause sudden air burst on your tubing tear
The portable electric pump with low battery next time also problem
Best is to go buy Lezyne or Birzman floor pump $50~80 with pressure guage, compatible with presta and schrader thread outlet, can be used for both bicycle and vehicle too
381eb4c8d6ce10e26d86fa6f9d493ae6
8854d922906c8f70fe408d5b107aa89d
poooff
Got money why not? I don't q like a peasant to use a communal pump at station
occifer
But it has a battery. Heat in car may cause it to possibly explode. Happened to others be4. Have to keep it insulated from heat if keep in car imo.
occifer
Wah first time hear that :s22:
PiPiChew
Is for emergency. Can use to pump bikes too.
To use it periodically it's a waste of time and energy to recharge it, like what TS said, petrol kiosk cheaper (free) better faster.
