EA8100 as wired AP with Singtel slow speed
ami422
Hi Guys, need your help, i have Singtel 1GB broadband, want to expand coverage, so added EA8100 , to test , i pluged EA 8100 with Singtel Router using wire.
I connected my phone to Singtel router to test speed, it was about 400Mbps,
But when i connected the phone to EA8100, speed was 90Mbps, both routers are side by side, i wonder why speed on EA8100 is so low.
Check using a Ethernet connection first to see if LAN connection from EA8100 is near to 1Gbps (say above 880Mbps). It could be that EA8100 connection speed with the main router is only 100Mbps.
Apex
I agree with Xiaofan
1. The EA8100 might be connected to to singtel router at 100mbps instead of 1Gbps
2. Suggest you swap the cable (between Singtel router and EA8100) first.
3. Or connect a wire device to EA8100 and do a test like what xiaofan suggested
Elijahonli
Check the ethernet cable.
It should be rated Cat5e or 6, if they are and stiil capped at 90mbps then try changing the cable.
j123123
May I know how to set up Linksys EA8100 as AP mode? using Asus rt-ac88u as main router, connect EA8100 to Asus router by wire, thanks in advance.
hairymonster
Did that help you resolve the problem?
To set it to ap mode, note that the main router ip (i.e. Your ac88u lan address, for example 192.168.1.1).
Set your Linksys router ip to 192.168.1.x where x is anything but 1.
Disable dhcp on the Linksys router. This just mean that only your main router is assigning ip address to your home devices.
Point the gateway in the Linksys router to the main router, that is 192.168.1.1.
Lastly configure the ssid of the Linksys router, encryption to be the same as the asus router.
Now you can roam seamlessly.
j123123
Lastly, point the gateway in the Linksys router to the main router, that is 192.168.1.1.
I didn't try yet, really appreciate.
