First build, buying tmr, have some final questions.
teh_slacker
Hey guys, this is my first time building a pc. I put together a list and going down to SLS tmr. I have some questions before I go and make the purchases.
Build:
CPU + Mobo : i5-4460+ ASRock H97M PRO4 @$413 PCThemes
RAM: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory @$99 PCThemes
SSD: Crucial BX100 250GB @$105 Amazon (purchased)
HDD: WD Blue 1TB @$77 PCThemes
GPU: Sapphire Radeon R9 380 4GB Nitro @$365 PCThemes
Case: Fractal Design Define Mini @$129 or NZXT H230 Black @$109 PCThemes
Power Supply: SeaSonic 520W 80+ Bronze Modular @$95 PCThemes
Keyboard: Corsair Vengeance K70 RGB $246 PCThemes
Mouse: Razer DeathAdder 2013 (currently used)
Total: $1424 (Define Mini) or $1404 (NZXT H230)
So the questions I have are:
1. I'm deciding between the Fractal Design Define Mini (SGD 129) and NZXT H230 Black (109) as they are pretty much the only 2 cases small enough to fit into my desk (new desk isn't a solution). How do these 2 cases perform against each other (temp, noise level, etc.). Aesthetically I personally prefer the Design Mini.
2. Do I need to buy additional fans or are the ones coming with the case sufficient?
3. Do I need to buy additional thermal paste? I know the stock cooler come pre-applied, just in case there is some problems and I need to reseat my CPU. Also additional zip ties, or cable management stuff in general?
4. My current monitor is a LG Flatron W2243T with a DVI-D and VGA Port, but I currently only have a VGA cable. Do I need to buy any cable for it to work/work better with the new graphics card?
5. What colours do the ram come in?
6. I decided to buy from PCThemes as I heard Trade Pac is closing down. Should I call them today/tmr before going to make sure the parts are in stocks or just go down there?
Thanks in advance for the answers. Any advice/suggestions will also be greatly appreciated.
princewenle
You can try to buy bundle for Case + PSU. I think alot cheaper. I suggest use Seasonic 650W, Full modular, 80+ Gold.
monikernemo
1. Just go for the one you like. Most of the the time it won't matter.
2. Nope you do not need to.
3. Nope you do not have to unless you really foresee yourself screwing up
4. Usually digital signals are better..? Vga is analogue. Aside, r9 380 don't have vga out put. May want to get a dvi d cable?
5. Usually black red and blue
6. Yeah I guess you can if you are really paranoid.
Sent from JARVIS using GAGT
teh_slacker
Thanks just want to make sure first build go smoothly :D
katata
1) choose what you like
2) No. If you have 2 -3 fans its more than enough. Go youtube and search are premium case fans worth it? And watch the video by linustechtips
3) No need. If you need to reseat etc, you can always go out and buy for like, $8? It wont happen la. When sitting your heatsink, just angle it properly. Then press it down and dont lift it up already. The moment you lift it up, air bubbles might get in, so just dont lift it up thats all. I have done 3 builds so far, its ok. Dont worry and think too much.
Cable management not necessary unless you overclocking where optimal airflow is required. I dont recommend cable management to first time builders because, there will be plenty of small issues that you cant foresee. E.g. dont bundle 24pin + 12 pin power cables together, your side panel might not close because they are sticking out too much.
If you make any errors, its harder to troubleshoot due to your lack of familiarity with the cables and tracing becomes harder. As well as having to cut cable ties to detach wires.
4) Recommend using DVI. The graphic card will come with a DVI cable in the box.
5)Depends on the ram. Google your ram, and look at images
6) First time builders, I recommend you buy from PCTheme they are a lot nicer and I dont really like TradePac. Make you wait there for so long while they take just 1 HDD for you. And their business is really sketchy
Goodshot
I feel very weird
1) $242 for a keyboard but use lao ya ssd
2) dun need a h97 board unless intend buy m2 ssd, if not h81 is cheaper alot and perform same.
3) I rather build I5 + h81 , gtx 970, Samsung ssd ( also same price,maybe cheaper but perform 30% more than ur build)
jayz89
I feel very weird
True
Mech keyboard no need buy so ex
darkarn
Or can always buy Model M for keyboard :p
Almost same price but better price-performance ratio
micheloving
Parts you buy are all so exp and overpriced .
Can save extra couple of hundred dollars just hire someone assembly for you @ 50 -100? U like carrot sia .
Shld have ask moneyface or other HW sexperts rec you basic rig hardware template base on ur budget to start 1st.
Not randomly wack from pricelist then post final questions one day before you go sls and let them chop you.
monikernemo
ps to hijack. is the Apex m800 the same as the apex illuminated for 199 over at pc themes pricelist cuz i dont see any apex m800 tho.
M800 is the one with the Logitech orion Spark 'omron-like' keys switches iirc? Got difference. Believe the illuminated and the raw versions just mainly rubber dome.
Not my cup of key (tea) :( the key travel is super duper short. Or maybe I used to MX blues Liao.
Its the dislike of their QC rather, that is heading in the razer direction...
Mmm you owned one K70 before?
I don't like how its overhyped though. And had a bad experience with their Corsair link software with H100i and how they attribute the problem to Windows 8.1 power savings issue.
Wah ask people to assemble for you chop more carrot worh :s22:
Some parts he buy liao (like SSD) llst. But I would go for something better (970) or cheaper (950) for gfx, PSU maybe the superflower leadex silver/FSP Aurum.
micheloving
I anyhow quote the price one I dun really know how much a hwz charges for just helping to assembly .
Maybe go there buy case ,hdd and motherboard cum cpu and pay bit more to assembly for u? Rest easy to assembly one.
CPU and motherboard assembly more tricky for newbies.
Nowadays buying parts online gives significant savings which can be used to buy better parts sia.
