Forum: Scammed of $100,000, but fault is not mine alone
Level42
Then in that 2 hours, he nonchalantly continued with his task when he could have 1) rush down to a bank 2) continue to hold the line 3) Force an account lock by entering a wrong password 3x
Brilliant idea! If the scammer change the password, should attempt multiple failed logins until the account is locked. Otherwise I prefer to take back control of the account.
Visor9999
As I said, it takes MANY MANY hands to clap.
The dinosaur era sms system is dinosaur era because most of the Planet Earth is in the dinosaur era.
The vulnerabilities will only be fixed when EVERYONE is up to speed.
Even if you put in some fancy translation gateway to help your new fangled hemorrhaging edge system communicate with the dinosaurs, how are you going to validate the information being fed to you from the dinosaurs? BTW the way the global networks are set up, there is NO WAY to bypass the dinosaurs.
A shiny diamond in a sea of mud is what you'll be. And guess what? Mud is sticky.
Then how come other countries never have so many scams like sg. Something must be wrong here which Govt need to look. Maybe suspend all paynow or new internal transfers etc
harbinger255
Then the next time they will change your userid first? :s13:
Never underestimate scammers....
tanakow
calling me not smart and my wife being unfaithful is not how u talk.
u can argue for all u want. No one is going to baby sit sinkies for their stupidity.
I was using an analogy using a hypothetical case to illustrate that getting the SPF to investigate a crime where the victim was at fault does not amount to babysitting people for their stupidity.
harbinger255
Oops. Yes, I just saw DBS can change User ID. 🙁
You can submit a request for forgetting your userid too.... but ultimately it's a race against time/scammer
If every scammer is as lenient as the 2 hour one... yeah sure.... plenty of reaction time.
aromilk
Boomers were right. Stick to passbooks!!!
harbinger255
It is unlikely you can change your bank userid.
Some can... OCBC used to use NRIC for userid, then PDPA came about so they had to make allowance to change userid.... I THINK I can still change it but too busy to verify it now
tanakow
The account may be locked. But the scammer is already logged in so he won't be kicked out. But some bank, I think OCBC for example, if you log into your account in one computer and then log in using another device, it will kick out the first account.
harbinger255
I was wondering about this.... tempted to test it but damn mafan... :ROFLMAO:
If account locked but existing session still can use... this one should complain to OCBC
tanakow
This is different. This change is performed by the system administrator or the application administrator. They probably go to the database directly to change. But an account holder is unlikely to be able to change his account name himself. That is because in most case the account name is used as a primary key. And renaming a primary key may not be so trivial.
harbinger255
This is different. This change is performed by the system administrator or the application administrator. They probably go to the database directly to change. But an account holder is unlikely to be able to change his account name.
It's gonna bug me too much if I don't check....
Yes, confirm can change your userid... or what they call access code (which is their workaround to unique key I suppose).... This part maybe they should disable... even though it needs token and all to change
Level42
For DBS, only one active session is allowed. Any new login kicks out the previous session. But I was thinking of the scenario where the scammers change password immediately after gaining access fraudulently. Meaning the victim no longer has access to his account. In lieu of a panic button, banks should consider allowing multiple failed logins to lock the account and kick out all sessions. Even if it is a prankster inconveniencing the legit account holder, I think it is worth erring on the side of caution. :giggle:
tanakow
If i were the scammer, the first thing I do is to change the password and the userid if possible. So the legit user cannot even try to log in using the old userid anymore.
That is why i don't think user should be allowed to change the userid.
harbinger255
I did just notice that you can use singpass to log in too.... didn't try it... not sure if it's a good or bad thing too....
For now... feels like another potential scam gateway
tanakow
For now... feels like another potential scam entry
For OCBC, i always use Singpass to login.
