Gfx, cable or monitor problem?
Gr3yham3
Hi all, i just got a new dell u2715h monitor recently, and i have to say that it looks great..
however, i noticed that recently, usually when i am gaming like Heroes of the storm, there will be a horizontal black band that flashes for a split second.. sometimes when i alt-tab out to desktop or chrome while the game is running, the screen will also turn black for a couple of seconds before returning back to the whatever i was doing
i am currently connecting the monitor to my sapphire 280 with the miniDP to DP cable that came with my monitor
should i check out the gfx card? how do i know if its a monitor problem? lastly, will changing a cable help?
Allanlee82
try connecting directly to the motherboard and see how
can also try other cable to see if the problem persist
radiobox
Either swap to onboard and test you having the same problem. Lazy like me, set the game setting to the max see it happen more frequently and set it to the lowest setting. Or run gpu stress test.
PS monitor your temperature also
Gr3yham3
what a reasonable temp then? nowadays sometimes when playing hots, the screen will blackout for 1-2secs before appearing again too
Gr3yham3
ok i lowered the resolution from 1440p to 20448x1152.. n it seems to have cleared up the problems.. could this mean that my comp was too hot as it cannot handle the graphics?
radiobox
what is the cpu and gpu temperature when gaming. Quick way is to open the desktop side panel, set back to your normal gaming setting, use a fan blow it and see it still have the same problem, if not than is heat problem. Need to know your cpu and gpu so can better troubleshoot
Goodshot
Dell monitor has a settings that will auto go sleep even ur pc doesn't sleep. Maybe u can find and turn it off
Gaiason
See u lucky or not lucky that's all. Might be monitor power issue.
Gr3yham3
how to know when it is a monitor power issue?
i tested out on other games, and the same problems seem to occur.. when i turn down the settings, like to a lower resolution, then the problems seem to go away...
when i am just surfing without any games running in the background, the problems dont occur at all
a miniDP to DP cable should not be the cause of the problem right? am i right to say that it is a GPU/CPU/system too stressed cannot handle 1440p gaming issue??
